    Change wifi settings
    Firmware installation
    2.4k
    • DjDemonDundefined
      DjDemonD
      So in an attempt to work out whether its the busy nature of my network thats causing the ajx timeouts I decided to setup a router just for the duet wifi and close by to ensure good signal with channels not being used by any other routers nearby (lol probably should have bought a duet and a lan cable).
      How do I go about resetting the duetwifi back to access point mode to change to this new network?
      www.precisionpiezo.co.uk
      • T3P3Tonyundefined
        T3P3Tony administrators
        So currently the only way to reset the DuetWifi into access point mode is to prevent it from seeing the configured network, see:
        https://www.duet3d.com/forum/thread.php?pid=1091#p1091
        Clearly one for a future firmware addition to alow this to be done more easily.
        www.duet3d.com
        • DjDemonDundefined
          DjDemonD
          Thanks Tony, that's not that problematic, it is only something that would normally be done very rarely.
          • peridotundefined
            peridot
            Can I suggest specifically that the WiFi module communicate with the MCU in such a way that WiFi setup can be done in G-code (in addition to the current method)? I had a few hours of frustration trying to get the initial WiFi set up, and from the fora I know I'm not the only one. To be able to plug the SD card into my computer and use the (existing!) G-codes to set up the network would have simplified the setup process dramatically.
            • DjDemonDundefined
              DjDemonD
              Yes being able to use the gcodes in the reprap gcode wiki would be useful. Unlike most wifi devices it's assumed we have USB console access via a PC to do initial setup so having a sort of "auto" wifi setup isn't really necessary. I'm sure it was well intentioned.
                @peridot:
                This is on the firmware wish list, but following a poll of users has a lower priority than some other features. See https://www.duet3d.com/forum/thread.php?pid=866#p866 and the earlier posts in that thread. What I actually plan to do is support a list of SSIDs and corresponding passwords in a file in the SD card, and some changes to ensure that this file cannot be read over the network for security reasons.
