    Using FAN Pin as a GPIO in Duet 3
    Using Duet Controllers
    • Saurabh
      Saurabh last edited by
      Hi Sir @dc42 , I've Duet 3 6HC V1.0 I want to use FAN out pins(out4, out5, ou6) as a GPIO out pin. Tried configuring the pins using
      ; configuration
      M950 P0 C"out4"
      M950 P1 C"out5"
      M950 P2 C"out6"
      ; console
      M42 P0 S1          ;  turn on pin out4
      M42 P1 S1          ; turn on pin out5
      M42 P2 S1          ; turn on pin out6
      But there is no output.
      Tried Inverting pin. Nothing works.
      How can I use this pins as a digital output pins?
      Thank you.
        Can you post your full config.g?
        Can you send M122 and M98 P"config.g" and post the response?
        What are you trying to control?
        • Saurabh
          Solved the issue, GPIO pin is working when a device is connected to that. Earlier I was checking output on out4 using a multimeter and it was showing almost 0V. Any idea how to detect this pwm signal on out4 using a multimeter or scope?
            dc42 administrators @Saurabh last edited by
            @Saurabh said in Using FAN Pin as a GPIO in Duet 3:
            Connect a pullup resistor between the OUT- pin and the adjacent positive supply pin.
