BerdAir and noise attenuation
I know there are a few BerdAir users, and I am mostly happy with the system. Apart from the noise levels. Especially now during work from home.
So, has anyone done enclosures and such for noise attenuation? If so, what did you end up building? How did you solve ventilation?
Side note, replacing the wiggle-pump with something like a Kamoer KVP8, is there any real difference in noise? Other pumps?
Thanks for any input.
This isn't going to help you with the noise problem.
My "solution" was to toss the unit in the trash and design a more typical setup using a small blower (as opposed to a fan).
Sorry I have no other solution to offer.
Good luck.
This helped a little.
Pump on vibration damping mounts, fuel filter on intake.
@fcwilt said in BerdAir and noise attenuation:
Good luck.
Yeah.. I am considering going back to blower. But, still need to experiment a bit
@janjoh I found this while looking for a mount: https://www.thingiverse.com/thing:3429324
Don't know how well it works.
