FAN0 not working, FAN2 wont stop
I cant seem to use FAN0 on my duet2wifi. not sure why, it was working now it doesn't
when I switch to use FAN2 it works. but wont turn off.. it just slows downPart Cooling Fan is using 24v 5015 Blower Fan (2 wire)
; Fans M950 F0 C"fan2" Q100 ;create fan 2 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
Post your full config.
Do the tiny mosfets near the fan ports look damaged?
