Panel Due not working
  • My Panel Due is connected and wired up correctly and powers on but stays in the "Connecting" State and doesn't send commands to the Duet. It worked before and I can't figure out why it would stop working. I have restarted both the Panel Due and the Duet with no luck.
    The common causes of that issue are:
    1. Bad connection on the data in or the data out wire. Or the pins swapped in the cable.
    2 Mismatched baud rate. The baud rate set in the M575 command in config.g must match he baud rate set on the Setup page of PanelDue. The usual value is 57600.
    HTH David
