Error Parsing Response
If it's a new printer setup, might want to stick to the latest stable release?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
If you want to stick with 3.3 beta 1, please post your config.g and the results of M122 and M98 P"config.g"
Which version of PanelDue firmware are you using?
I am using PanelDue 3.2.9
Are you running the Duet in standalone mode, or with an attached SBC? I am fairly sure that messages doesn't come from RepRapFirmware, so I think it must come from PanelDue or from DSF.
I am running it in stand alone mode.
@taylo708 This message generated whenever the status-updates from RRF cannot be parsed correctly. Can you confirm that this is new with RRF 3.3beta1 and you did not have this issue before?
If so, please post your
config.g
so I can investigate the issue. -
I was running 3.3 beta1. I also have a 3.3 beta I’m not sure if they are different or not. I went back to 3.3 beta and am still getting the same parsing error.
@taylo708 Please provide the following information:
Output of
M115
andM122
as well as yourconfig.g
This post is deleted! -
m115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3beta ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-01-20 16:37:22
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (standalone mode) Board ID: 08DJM-956BA-NA3TJ-6JTD0-3S06T-1V86T Used output buffers: 1 of 40 (23 max) === RTOS === Static ram: 149784 Dynamic ram: 90596 of which 24 recycled Never used RAM 110268, free system stack 178 words Tasks: NETWORK(ready,222) ETHERNET(blocked,117) HEAT(blocked,280) CanReceiv(blocked,887) CanSender(blocked,365) CanClock(blocked,326) TMC(blocked,49) MAIN(running,1120) IDLE(ready,20) Owned mutexes: === Platform === Last reset 01:49:39 ago, cause: software Last software reset at 2021-02-22 17:03, reason: User, GCodes spinning, available RAM 110268, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 45.4, current 45.6, max 46.0 Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 0, standstill, reads 63181, writes 0 timeouts 0, SG min/max not available Driver 1: position 0, standstill, reads 63181, writes 0 timeouts 0, SG min/max not available Driver 2: position 0, standstill, reads 63182, writes 0 timeouts 0, SG min/max not available Driver 3: position 0, standstill, reads 63182, writes 0 timeouts 0, SG min/max not available Driver 4: position 0, standstill, reads 63182, writes 0 timeouts 0, SG min/max not available Driver 5: position 0, standstill, reads 63181, writes 0 timeouts 0, SG min/max not available Date/time: 2021-02-22 18:52:55 Slowest loop: 25.59ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 2.3ms, write time 3.3ms, max retries 0 === Move === DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 2044, send timeouts 0, received 2092, lost 0, longest wait 4ms for reply type 6024, peak Tx sync delay 147, free buffers 48 (min 47) === Network === Slowest loop: 26.25ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 1 of 8 - Ethernet - State: active Error counts: 0 0 1 0 0 Socket states: 5 2 2 2 2 0 0 0```
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.1 on Wed Jan 13 2021 13:45:55 GMT-0500 (Eastern Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"DATA DRIVEN PERFORMANCE" ; set printer name ; Network M552 S1 192.168.254.57 ; Enable network G4 S5 ; Drives M569 P40.0 R0 S0 T6:6:6:0 ; physical drive 40 goes forwards M569 P41.0 R0 S1 T6:6:6:0 ; physical drive 41 goes forwards M569 P42.0 R0 S0 T6:6:6:0 ; physical drive 42 goes forwards M569 P0.0 S1 ; physical drive 20 goes forwards M584 X40.0 Y41.0 Z42.0 E0.0 ; set drive mapping M350 E16 I0 ; configure microstepping with interpolation M92 X266.666 Y266.666 Z640.00 E130.00 ; set steps per mm M350 E32 M566 X300.00 Y300.00 Z20.00 E30.00 ; set maximum Jerk (mm/min) M203 X7000.00 Y7000.00 Z1000.00 E3000.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z200 E2500 ; set accelerations (mm/s^2) M906 E750 I30 ; set motor currents (mA) M84 S30 ; Disable motor idle current reduction ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X600 Y600 Z600 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!20.io2.in" ; configure active-high endstop for low end on X via pin 124.io2.in M574 Y1 S1 P"!io3.in" ; configure active-high endstop for low end on Y via pin io3.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^20.io0.in" H2 F120 T600 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X30 Y90 Z2 ; set Z probe trigger value, offset and trigger height M557 X30:570 Y90:510 S28.5 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3500 ; configure sensor 0 as thermistor on pin temp1 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 R0.086 C1484.1 D36.00 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M570 H0 T40 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"spi.cs0" Y"thermocouple-max31856" "K" ; configure sensor 1 as thermocouple via CS pin spi.cs0 M950 H1 C"out1" T1 ; create nozzle heater output on 124.out0 and map it to sensor 1 M307 H1 R2.808 C254.0 D9.08 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S350 ; set temperature limit for heater 1 to 350C M308 S2 P"temp1" Y"thermistor" T100000 B3500; configure sensor 2 as thermistor on pin temp0 M950 H2 C"io1.out" T2 ; create chamber heater output on out1 and map it to sensor 2 M307 H2 A11 C99000 D2000 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S70 ; set temperature limit for heater 2 to 70C ; Fans M950 F0 C"20.out1" Q500 ; create fan 0 on pin 20.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X-30 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue
Is there any solution for this? We have the same problem with 3.3RC2 and 3.2.11 (PanelDue). We do multiple machines a week but this is our first machine where we get this problem.
What we tried allready:
- New LCD screen
- New cables between board and LCD
- Firmware 3.2 to 3.3RC2
- LCD Firmware 3.2.1 and 3.2.11
@dvmourik I can think of the following possible explanations:
- Faulty hardware: this could be the Duet, the cable, or the PanelDue. You've replaced the cable and the PanelDue, but have you replaced the Duet?
- Something different in the environment, e.g. something that is normally grounded isn't on this particular machine, and that is causing interference
- An obscure firmware bug that is causing RRF to return invalid JSON because of the way the machine is configured. Is the config.g file on this machine the same as on the working machines?
Does the machine respond to commands sent from the PanelDue, e.g. the Home All button?
I just received a brand new panel due to upgrade an old one.
The new 7i causes these errors.
The old panel with extra board that plugged into it probably is 5 years old works fine.
I'm running the latest stable release of the duet firmware and also the current latest firmware for the panel 7i.Any idea why this is causing me grief?
Considering returning the PanelDue as I believe something is wrong with it if the old PanelDue works fine.Anything you recommend???
@pete1961 which firmware is the older PanelDue running?
I'm going to say at present after making a shorter cable from scratch the errors have stopped.
I went from about a 24" cable down to a 10" Cable.
I will come back here if I see more errors. -
@pete1961 Using a braid or twist on the cable can help. so can using a higher gauge or shielding.
Yes a better cable is in order with the 10" cable I fabricated the errors are more spurious than previously but still around.
The cabling is obviously the cause of this problem. -
@pete1961 said in Error Parsing Response:
The cabling is obviously the cause of this problem.24" (600mm) is not too long (I have a 1.5m cable on one of my machines), however there is a limit on the resistance per conductor. See the wiki for details.
