    Stuttering stepper motors and under voltage
    • JeroenZvZ
      JeroenZvZ last edited by
      Well,
      The stepper motors on my Kossel XL started stuttering and I did a M122. Could anyone point me to the culprit? I wonder if it are the drivers, a bad connection to the stepper motors or maybe the power supply connection (corsair sf450). Stepper motors are 2.4a and configured to 1.9a in the config.g. What steps can i follow to find out what the problem is? The board seems to be constantly powered as I don't see any leds flickering when the stuttering is there. Below my 122 results with the under voltage events that occurred:
      DuetWifi on 1.18, no paneldue attached, printing by uploading through the webinterface.
      Used output buffers: 1 of 32 (9 max)
      Static ram used: 20320
      Dynamic ram used: 72784
      Recycled dynamic ram: 1104
      Stack ram used: 968 current, 8104 maximum
      Never used ram: 28760
      Last reset 00:08:34 ago, cause: power up
      Last software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
      Spinning module during software reset: GCodes, available RAM 33336 bytes (slot 4)
      Error status: 0
      Free file entries: 8
      SD card longest block write time: 4.7ms
      MCU temperature: min 30.6, current 33.0, max 37.1
      Supply voltage: min 9.3, current 10.0, max 12.2, under voltage events: 11, over voltage events: 0
      Driver 0: stalled
      Driver 1: stalled
      Driver 2: stalled
      Driver 3: standstill
      Driver 4: standstill
      Date/time: 2017-08-10 00:36:04
      Slowest main loop (seconds): 0.082901; fastest: 0.000061
      MaxReps: 3, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 1, completed moves: 0
      Bed compensation in use: none
      Probe change coordinates:
      Bed heater = 0, chamber heater = -1
      Heater 0 is on, I-accum = 0.8
      Heater 1 is on, I-accum = 0.4
      Segments left: 0
      Stack records: 1 allocated, 1 in use
      Movement lock held by file
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 1 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      WiFiServer is running
      SPI underruns 0, overruns 0
      === Webserver ===
      HTTP sessions: 1 of 8
        The first thing to check is that the screws in the VIN terminal block are tight.
