KISS Slicer time estimate not supported in DWC3.2.2
  • I just noticed that DWC 3.2.2 does not recognize KISSlicers print time markers while DWC 2.0.4 does (I am currently printing the same file on a machine running the newer and another running the older version of DWC).
    KISSlicer version is 2 alpha 2.0.6
    This is the time estimate information at the end of a gcode file
    ; Calculated-during-export Build Time: 193.99 minutes
    ; Estimated-in-GUI Build Time:         194.01 minutes
    ; Estimated-in-GUI Build Cost:         $0.84
    ; Filament used per extruder:
    ;    Ext #1  =  8076.61 mm  (19.427 cm^3)
    ; *** Extrusion Time Breakdown ***
    ; * estimated time in [s]
    ; * before possibly slowing down for 'cool'
    ; * not including Z-travel
    ;	| Ext #1  | Path Type
    ;	| 140.553 | Jump Path                  |
    ;	| 0       | Pillar Path                |
    ;	> 0       > Raft Path                  >
    ;	| 0       | Support Interface Path     |
    ;	| 0       | Support (may Stack) Path   |
    ;	| 2786.39 | Perimeter Path             |
    ;	> 5863.62 > Loop Path                  >
    ;	| 588.503 | Solid Path                 |
    ;	| 134.414 | Sparse Infill Path         |
    ;	| 1443.05 | Stacked Sparse Infill Path |
    ;	> 65.9231 > Destring/Wipe/Jump Path    >
    ;	| 201.588 | Crown Path                 |
    ;	| 12.2082 | Prime Pillar Path          |
    ;	| 0       | Purge Path                 |
    ;	> 316.806 > Travel/Ironing Path        >
    ;	| 0       | Pause Point                |
    ;	| 86.4    | Extruder Warm-Up           |
    ; Total estimated (pre-cool) minutes: 193.99
  • Interesting. Works fine here. Same version of Kisslicer.
    I wonder what other differences there are between our machines.
    This is from Duet 6HC.
    I checked on Duet 3 mini 5+ - also works there for me.
