Wiring up Duet to turn on an atx psu when pc button is pressed
I was wondering if anyone could offer some guidance, I am contemplating if it is possible to wire up my pc case power button onto the duet wifi, and have it when pressed execute the necessary GCode to turn on the atx psu. I know the duet can already control the psu but I want it to turn on the psu when the pc power button is pressed, from my research I believe it might be possible to use a spare endstop on the board to trigger the necessary GCode. If anyone could help guide me in the changes I would need to make I would be very grateful.
Currently the psu is being controlled by an arduino nano powered by the 5V standby rail which allows the pc power button to work.
Thankyou
