    DuetWebServer Nginx proxy issues
    1
    113
    • keyz182undefined
      keyz182
      I'm trying to get DuetWebServer (on a Pi4) running behind an Nginx proxy.
      It kind of works - I see what's going on, but it seems to be entirely read-only.
      If I try to upload a file, I get "index.js:220 Error: Operation failed (Reason: )" with a 400 error returned on the PUT (with no error message/no content).
      Same with POSTs when trying to execute/do anything - e.g. POST to http://<snip>/machine/code returns a 400 with no content.
      My nginx config is
      map $http_upgrade $connection_upgrade {
          default upgrade;
          '' close;
      upstream dws {
          server 127.0.0.1:8080;
      server {
          listen        80;
          server_name   <snip>;
          location / {
              proxy_pass         http://dws;
              proxy_http_version 1.1;
              proxy_set_header   Upgrade $http_upgrade;
              proxy_set_header   Connection "Upgrade";
              proxy_set_header   Host $host;
              proxy_cache_bypass $http_upgrade;
              proxy_set_header   X-Forwarded-For $proxy_add_x_forwarded_for;
              proxy_set_header   X-Forwarded-Proto $scheme;
      And my /opt/dsf/conf/http.json is
        "Logging": {
          "LogLevel": {
            "Default": "Information"
        "Kestrel": {
          "Endpoints": {
            "Http": {
              "Url": "http://*:8080"
        "KeepAliveInterval": 30,
        "ModelRetryDelay": 5000,
        "UseStaticFiles": true,
        "DefaultWebDirectory": "/opt/dsf/sd/www",
        "MaxAge": 3600,
        "SocketPath": "/var/run/dsf/dcs.sock",
        "WebSocketBufferSize": 8192
      I think my issue lies in the Nginx config, as I don't see any logging triggered by the request in the DWS logs (logs appear fine if I go to port 8080), but I'm not 100% sure.
      Has anyone else successfully done this?
