Solved Duet 3 Mini 5+ - .bin to .uf2conv.py ?
I successfully compiled Duet3Firmware_Mini5plus.bin but the board is expecting a .uf2 file.
The tool uf2conv is provided in the tools folder.My question is: What settings / arguments (offset?) is needed to convert into a format the Duet 3 Mini 5+ is expecting?
it should do it automatically at the end of the build process. It has for me in the past.
You may need to install python I think to get it work -
Thanks. I'm using a newer version of python and the cmd is py not python. That why it didn't work.
It's working now.
