print bed moves down when print start
hello peeps,
i have this weird issue with my hevo that whenever i start a print the printbed moves completely down whilst when i home the axis x,y,z it does this correct it's only whenever i upload a print (i use cura) when this happens checking my system files it appears that i don't have a start.g is this necessary? or does this issue has to do with the cura settings? i'll upload my home files and config for maybe you peeps can find something that isn't correctconfig.g, config-override.g , homeall.g , homex.g , homey.g , homez.g
and i'll also add a screen from my cura code.
thanks in advance
from your homeall.g
G1 H1 Z500 F360 ; move Z up stopping at the endstop
@Veti said in print bed moves down when print start:
from your homeall.g
my z stop is on top so when i home it works fine it's just when i upload a print it moves down no idea if that's the issue, i'm a total noob especially in g codes etc.
do i have to remove this line or make it a negative number?
@Dentokke said in print bed moves down when print start:
your z stop is configued for min.
M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
min is at z=0
z500 means move 500mm away from the nozzle.
@Veti ok thank you i'll try that
i would suggest you generate the homing scripts again in the configurator.
your homing scripts are not correct for z.
a homescript should look like this for your (movement values are not adjusted for your printer)
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 01 2021 16:16:20 GMT+0100 (Central European Standard Time)
G91 ; relative positioning
G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-205 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
@Veti i used the duet config tool for all this so perhaps i'll try it again
It will depend on if you've chosen the z endstop as min or max end of travel.
