    ToolChanger tool data
    • K01571N3Nundefined
      K01571N3N
      https://forum.duet3d.com/topic/20693/which-tool-is-enabled-after-startup
      @taconite wrote earlier about this, and I started doing the same on my own printer. I had the following problem:
      DIY ToolChanger with Duet 3 6HC, 3HC and Raspberry pi.
      If i write to console
      M560 P"0:/sys/test"
      or run macro like that
      M560 P"/sys/test"
      <!-- **EoF** -->
      or whatever else, "Error: M560: Can't open file test for writing" appears...
      If i write
      M98 P"0:/sys/test
      it will run that macro.
      Is Raspberry pi somehow causing the trouble here or what?
      • chrishammundefined
        chrishamm administrators
        It looks like M560 isn't implemented in DSF yet so I'll add that to the TODO list.
        Nevertheless M28/29 should work. Can you use that instead?
        Duet software engineer
        K01571N3Nundefined 1 Reply Last reply Reply Quote 0
          K01571N3N @chrishamm
          @chrishamm i will try that. Is this correct way to do that? So it will make a file to sys directory named ToolActive.g and in this file is text T0?
          toolchange macro T0
          ; T0
          M28 /sys/ToolActive.g
          T0
          M29
            chrishamm administrators @K01571N3N
            @K01571N3N Yes, exactly.
