Using duex.pwm4 as fan???
I've got the config below. As far as I can tell, that is correct. I've wired up the 3 pin connector
Rd__Bk
just like in the diagram. What could I be doing wrong?M950 F4 C"duex.pwm4" Q500 M106 P4 C"Tool 3 Blower" S0 H-1 M950 F5 C"duex.pwm5" Q500 M106 P5 C"Cold Section" S1 H4 T80
Is there a reason you are not using the duex.fan# outputs?
@fcwilt all used up and 2 of them are blown
@gnydick said in Using duex.pwm4 as fan???:
How about the heater outputs?
The 3 pin headers only have 5 volts on them.
@fcwilt you mean the green screw downs?
Yes - they are shared with the .pwm outputs but have MOSFETs for driving higher powered loads.
@fcwilt oooooh, i didn't realize it worked that way. I knew they are shared, just thought when configured, you only got output on the 3pin
I don't think so.
It should be easy to test.
@fcwilt I LOVE YOU!!! it works.
OK... good to know.
Glad I was able to help.
