    [RRF 3.2.2] Can't figure out the offset between Z0 and mesh
    1.6k
    • fcwiltundefined
      fcwilt @pkos
      @pkos said in [RRF 3.2.2] Can't figure out the offset between Z0 and mesh:
      I am pretty much stuck as well 😉 It totally baffles me.
      Here is something to try.
      When doing the G30 you are positioning the probe at one of the probe points for the grid? Yes? No?
      IF that is the case try a position that is in the middle of 4 grid points.
      I will be racking my brain trying to recall anything else that might be causing the problem.
      pkosundefined 1 Reply Last reply Reply Quote 0
      • pkosundefined
        pkos @fcwilt
        @fcwilt Correct. I am probing exactly one of those spots. I'll try between the 4 tomorrow assuming the printer will even start. Currently, the board refuses to launch (different, known issue with the minis, waiting for a board replacement). If it were only on this printer, I'd think it's the board at fault and leave it at that 😉 But the other printer has the same problem, so yeah.
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
        • fcwiltundefined
          fcwilt @pkos
          Known issue?
          I have 4 Minis - what goes wrong?
          • pkosundefined
            pkos
            There's apparently a batch that can result in loss of connection to the SD card.
            It's described here: https://forum.duet3d.com/topic/21004/duet-3-mini-5-unable-to-connect-via-browser/24?_=1615068562632
            • pkosundefined
              pkos
              OK. Now I am even more lost...
              3.3b1 solves the problem. Height map is scanned and loaded properly.
              Same steps as above exactly. Worked first time.
              Now to try a print! 🙂
              fcwiltundefined 1 Reply Last reply Reply Quote 1
              • fcwiltundefined
                fcwilt @pkos
                Glad to hear it is working.
                I wonder why.
                Was it the update to the new version that did it or was it the update process itself that fixed something?
                Curious.
                I know I have loaded height maps under 3.2.2 but did I create them under 3.2.2? I don't remember.
                I need breakfast.
                • pkosundefined
                  pkos
                  It must be the update. I rolled back to 3.2.2 and the issue came back.
                  Each time, I kinda reset the whole process, so all csv's deleted, etc etc.
                  • fcwiltundefined
                    fcwilt @pkos
                    Good to know.
                    I will have to generate a new height map to see if the problem occurs for me as well.
                    I hope not as I don't like using beta firmware.
                    • pkosundefined
                      pkos
                      Happy too fast...
                      It solves the issue with Switchwire, but does not solve the issue on 2.4.
                      I am still getting that offset even on 3.3b1. Damn...
                      • fcwiltundefined
                        fcwilt
                        I went ahead and created a 9 point (to save time) height map under firmware v3.2.2.
                        No issues.
                        So I'm still baffled by what is happening on your printers.
                        • fcwiltundefined
                          fcwilt
                          I've been trying to create your problem on my printer and I just cannot.
                          I tried messing with the probe Z trigger height.
                          I even edited the CSV file adding 1 to each point.
                          So far I haven't found out what conditions cause the error.
                          • pkosundefined
                            pkos
                            Well assuming 3.3 comes out of beta soon, I will close this for now. I have a workaround for 3.2.2 that always works... it's just weird an annoying is all 😉
