    M303 result message M307 inconsistent with config-override.g
    m303 config-override.g m307
    • louvannaundefined
      louvanna
      3/7/2021, 10:28:48 AM M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-02-11
      The result of an heater auto-tune provides a prototype line for inclusion in a config, or use M500 to write into config-override.g.
      The message and the written lines are inconsistent. Not sure it matters .
      3/7/2021, 9:46:34 AM Auto tuning heater 1 completed after 3 idle and 5 tuning cycles in 347 seconds. This heater needs the following M307 command:
      M307 H1 R3.758 C126.5 D7.32 S1.00 V12.2
      Send M500 to save this command in config-override.g
      The line in the config-override.g is different.
      1. Numerical precisions
      2. inclusion of B0
      M307 H1 R3.758 C126.499:126.499 D7.32 S1.00 V12.2 B0
      Not being fully aware of the defaults, etc., so I cannot say that this important. This may simply be 'house keeping'.
      • fcwiltundefined
        fcwilt
        To avoid confusion I think they should be the same.
        Make a post under the firmware wishlist category and suggest this.
