    Using another Raspberry SPI Shield
    • No2undefined
      No2
      Hi there,
      I was wondering if there is a way to configure the CS pin the duet is listening to from the raspberry (and/or which one it is currently using) in order to add another SPI shield on my raspberry
      • gaweyoundefined
        gaweyo
        You can change the device node, which determine the CS pin. The extra trfrdy pin is configurable.
        But it's not adviced to share the spi bus, probably better off using the second spi bus on the pi.
        In any case see /opt/dsf/conf/config.json or something similar
