    3.3b1 SBC KISS slicer filament usage and print time estimates
    Beta Firmware
    • oliofundefined
      oliof
      KISS Slicer 2.0 alpha 6 filament usage and print time estimates aren't detected by 3.3b1 in SBC mode.
      Attached is a sample file so filters can be adjusted.
      (I guess this goes to @chrishamm again)
      sample_cube-KISS.gcode
      • chrishammundefined
        chrishamm administrators
        Thanks once again, here the new escaped RegExs for the filament usage:
        Ext\\s*\\#\\d+\\D+(?<mm>\\d+\\.?\\d*)
        And for the print time:
        Total estimated \\(pre-cool\\) minutes: ((?<m>\\d+\\.?\\d*))
        I'll add them to the next release too. HTH!
        Duet software engineer
        • oliofundefined
          oliof
          duetcontrolserver fails to start with the Regex for filament usage. I am currently not able to debug it.
          EDIT: Also, is there a limit to the filesize where these filters are applied? The print time estimate is shown for the 4MB example file I have attached, but not with a larger file (129MB) sliced with the same settings. (disregard, this was a file missing the .gcode extension).
            Sorry, looks like I forgot to escape the last backslash from the filament usage, now updated. The new escaped regex should work.
            • oliofundefined
              oliof
              I just started a 26 hour print on the test machine ... I will fuzz with duetcontrolserver after that's failed or finished (-:
                dc42 administrators @oliof
                @oliof said in 3.3b1 SBC KISS slicer filament usage and print time estimates:
                I have confirmed that this file is already analysed correctly in standalone mode.
