Z Homing position different by zero
Zero layer of a test cube of 50x50x50 mm.
There are essentially 2 problems ....- Brim is not accurate. Perhaps it is due to poor adherence to the plan.
- the filling is not precise and does not overlap the wall.
Maybe I need to change something in the settings. But what?
In addition to modifying the speed of the walls again, with this larger test, the result looks better (apart from Layer 0). Perhaps, and this is my suspicion, the airflow of the layers fan is not suitable for small objects. If this is the case, I will have to redo the duct providing a vertical flow all around the hotend. So a more distributed flow than this, which remains concentrated in one corner.
At Layer 24 I paused the print to take a photo from above. In resuming the print you notice the slight error, especially on the left corner of the previous photo.
Layer 136:
You see various errors / problems along the edges. They are almost certainly due to a non-optimal Jerk setting. Tomorrow I will try to improve!
Anyway ... congratulations to everyone because this electronics are phenomenal!
And with these 5 photos I close the discussion.
Thank you all
