    Duet 3 6HC Output_0 always on
    1.6k
    • tpyoknigundefined
      tpyoknig
      I was configuring my Duet 3 and noticed that the bed was inconsistently getting power and noted that the 15A fuse was very loose. I replaced this fuse - but now even with just a power supply input for the bed - there is voltage coming out of OUTPUT_0.Duet3.jpg
      This is causing the bed to heat without being instructed to do so. I've reflashed the firmware to no change and changed out power supplies and replaced the bed entirely.
      In the above photo, everything is disconnected and only 24V from a meanwell 350W power supply is connected. I have a 500W power supply that is usually connected here that has the same behavior. I was redirected to here by Filastruder for support/warranty purposes.
      To make it clear, I'm aware I don't have anything connected to VIN. I'm stripped this down to the bare minimum to demonstrate the issue. Anything there is power applied for the bed, there is power on OUTPUT_0 where my bed is usually plugged in. I have my multimeter plugged in here to demonstrate the issue rather than heating my bed as it doesn't stop heating it until the power is disconnected physically.
      • razrudyundefined
        razrudy
        You're wiring is wrong
        The input should be top first 2 pins
        • tpyoknigundefined
          tpyoknig
          @razrudy I'm not testing VIN - so my wiring is correct for testing voltage for the bed.
          • razrudyundefined
            razrudy
            Ok that make sense somehow. But if you don't power the board how the board will send the command to open/close OUT_0. May sound stupid what I say but why you don't just power up everything the right way?
            Connect VIN and after that the bed PSU and test.
            No offense just an idea to try out.
            Also I am taking in consideration that the "GND" is the one giving the command and ( I may be wrong) but the V+ is "always on" between input and output on OUT_0 as long as the fuse is ok
            fcwiltundefined tpyoknigundefined 2 Replies Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt @razrudy
              @razrudy said in Duet 3 6HC Output_0 always on:
              Correct.
              • fcwiltundefined
                fcwilt @tpyoknig
                @tpyoknig said in Duet 3 6HC Output_0 always on:
                That is not a valid test. The input to the MOSFET that controls power to that output doesn't have a valid signal to control its state.
                • tpyoknigundefined
                  tpyoknig
                  Fair point, but this is the same behavior that it does when everything else is connected. What would be a good/valid test to perform?
                  • tpyoknigundefined
                    tpyoknig @razrudy
                    @razrudy Ok, so I'll connect both and give it a shot and see what the results are and will report back.
                    • fcwiltundefined
                      fcwilt @tpyoknig
                      So you are saying with power applied to VIN and OUT 0 POWER IN and a valid config.g file OUT 0 is active?
                      • tpyoknigundefined
                        tpyoknig
                        @fcwilt Correct. Anytime there is power applied to OUTPUT 0 POWER IN then OUT 0 will output power as noted by my bed led lighting up.
                        Having power on VIN or not doesn't change that. Its why in my testing I disconnected the SBC that had the config and disconnected any and everything else to reproduce the issue with minimal things connected.
                        Here's the same with VIN and OUTPUT Power IN showing power being supplied - when not being told to do so by any config.
                        • fcwiltundefined
                          fcwilt @tpyoknig
                          @tpyoknig
                          Interesting.
                          Post your config.g file please using the </> tag.
                          tpyoknigundefined 1 Reply Last reply Reply Quote 0
                          • razrudyundefined
                            razrudy
                            Remove the groung from OUT_0 input and leave only the V+ see what's happening.
                            This is how is mine connected
                            Still building my enclosure so a little messy at this point.
                            Also the OUT_0 output is controlling a mosfet ( that's the reason for that "thick" wires on output )
                            I also have separate PSU for the bed controlled by the mosfet.
                            Another idea.....connect the temp sensor for bed just to eliminate this from equation too
                            tpyoknigundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                            • tpyoknigundefined
                              tpyoknig @fcwilt
                              @fcwilt My config, right now is a default/stock one from RRF's configurator that I've not reconfigured as I replaced/reflashed firmware/image etc to troubleshoot this. This is was my config prior
                              ; GCode Dictionary: https://duet3d.dozuki.com/Wiki/Gcode
                              G21                                                             ; work in mm
                              M555 P2                                                         ; Set Marlin-style output
                              G90                                                             ; send absolute coordinates...
                              M83                                                             ; ...but relative extruder moves
                              M550 P"Duet 3"                                                  ; set printer name
                              M669 K1                                                         ; select CoreXY mode
                              ; Drive Mapping/Config
                              M569 P0.0 S0 D3 V5 H5                                        ; Drive 0.0 E goes forwards   / Extruder
                              M569 P0.1 S1 D3 V5 H5                                        ; Drive 0.0 X goes backwards  / Left
                              M569 P0.2 S1 D3 V5 H5                                        ; Drive 0.1 Y goes backwards  / Right
                              M569 P0.3 S1 D3 V5 H5                                        ; Drive 0.2 Z goes backwards  / Left Z
                              M569 P0.4 S1 D3 V5 H5                                        ; Drive 0.4 Z goes backwards  / Right Z
                              M569 P0.5 S1 D3 V5 H5                                        ; Drive 0.5 Z goes backwards  / Back Z - triple Z
                              M584 E0.0 X0.1 Y0.2 Z0.3:0.4:0.5                                ; set drive mapping - triple Z
                              M906 X800 Y800 Z800 E800 I30
                              ; Leveling
                              M350 X16 Y16 Z16:16:16 E16 I1                                         ; configure microstepping with interpolation
                              M915 X Y S2 F0 H200 			; X / Y Axes
                              M566 X900.00 Y900.00 Z60 E3000           ; set maximum instantaneous speed changes (mm/min)
                              M201 X2500.00 Y2500.00 Z100.00 E2500.00        ; set accelerations (mm/s^2)
                              M203 X12600 Y12600 Z900 E25200      ; Maximum speeds (mm/min)
                              M204 P3000 T3000
                              M208 X0:300 Y0:300 Z0:330                                             ; set axis min & max for X/Y
                              M92 X99.60 Y100.35 Z1604.11 E419.6
                              M84 S30 												        ; Set idle timeout
                              M574 X1 Y1 S3                                                   ; configure sensorless endstop for low end on X & Y
                              ; Bltouch
                              M950 S0 C"io7.out"                                              ; create servo pin 0 for BLTouch
                              M558 P9 C"^io7.in" H5 R1 F800 T6000 A5 S0.02 B1                 ; set Z probe type to bltouch and the dive height + speeds
                              M671 X-25:335:152 Y40:40:350 S2                                   ; leadscrews at left (connected to Z) and right (connected to E1), Rear Z is E2, set max correction to 3.5mm (S)
                              M557 X20:280 Y20:280 S20                                        ; define mesh grid (subtracting values for mesh to account for Z probe offset in X/Y)
                              G31 P25 X-19 Y13 Z1.980                                        ; set Z probe trigger value, offset and trigger height
                              ; Mesh Bed Compensation
                              M376 H5									                        ; Set taper height 10mm
                              ; Thermistors
                              M308 S0 P"temp0" Y"thermistor" T100000 B4138                    ; configure sensor 0 as thermistor on pin temp0 / Bed
                              M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8           ; configure sensor 1 as thermistor on pin temp1 / HotEnd
                              M950 H0 C"out0" T0                                              ; create bed heater output on out0 and map it to sensor 0 / Bed
                              M950 H1 C"out1" T1                                              ; create nozzle heater output on out1 and map it to sensor 1 / HotEnd
                              ; Bed
                              M140 H0                                                         ; map heated bed to heater 0
                              M307 H0 B0 R0.292 C478.8 D1.12 S0.90 V23.7                      ; disable bang-bang mode for the bed heater and set PWM limit
                              ; Hotend
                              M307 H1 R1.523 C339.7 D6.57 S1.00 V23.9
                              M570 S180 H1 P10 T15                                            ; Hotend allows 10sec for anomaly, permits 15deg excursion, abandons print after 180s
                              ;   Part Cooling
                              M950 F0 C"out2" Q500                                            ; create fan 0 on pin out2 and set its frequency
                              M106 P0 C"PartCoolingFan" S0 H-1                                ; set fan 0 name and value. Thermostatic control is turned off
                              ;   Hotend
                              M950 F1 C"out3" Q500                                            ; create fan 1 on pin out3 and set its frequency
                              M106 P1 C"HotEndFan" S1 H1 T45                                  ; set fan 1 name and value. Thermostatic control is turned on
                              M563 P0 S"E3DHotEnd" D0 H1 F0                                   ; define tool 0
                              G10 P0 X0 Y0 Z0 R0 S0                                           ; set tool 0 axis offsets
                              M575 P1 S1 B57600                                               ; enable support for PanelDue
                              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; set voltage thresholds and actions to run on power loss
                              T0                                                              ; select first tool
                              ; FEEDRATE CONVERSIONS
                              		; 20mm/s = F1200
                                  	; 35mm/s = F2100
                              		; 50mm/s = F3000
                              		; 70mm/s = F4200
                              		; 100mm/s = F6000
                              		; 120mm/s = F7200
                              		; 133mm/s = F8000
                              It keeps being flagged as spam.
                              • tpyoknigundefined
                                tpyoknig @razrudy
                                @razrudy With the thermistor connected and the bed connected, it still heats. It goes into fault state but power is still being supplied on OUTPUT_O regardless which is what has me scratching my head. Removing either lead positive or negative from INPUT_0 stops the power that's being output for OUTPUT_0 as expected.
                                • fcwiltundefined
                                  fcwilt @razrudy
                                  Why is the OUT_0 output controlling a MOSFET?
                                  razrudyundefined 1 Reply Last reply Reply Quote 0
                                  • razrudyundefined
                                    razrudy
                                    This is my working config , not complete but everything works
                                    ; Configuration for Chiron+Titan Aero+Volcano+BlTouch+ SBC Pi4
                                    G21                                                        ; works in mm
                                    M550 P"Chiron"                                             ; set printer name
                                    M569 P0.0 S1                                               ; physical drive 0.0 goes forwards X
                                    M569 P0.1 S0                                               ; physical drive 0.1 goes backwards Y
                                    M569 P0.2 S0                                               ; physical drive 0.2 goes bacwards ZL
                                    M569 P0.3 S0                                               ; physical drive 0.3 goes backwards ZR
                                    M569 P0.4 S1 D2                                            ; physical drive 0.4 goes forwards E
                                    M584 X0 Y1 Z2:3 E4                                         ; set drive mapping
                                    M350 X16 Y16 Z16 E16 I1                                    ; configure microstepping with interpolation
                                    M92  X80 Y100 Z400 E400.96                                 ; set steps per mm
                                    ;M566 X1200 Y1200 Z12 E120                                  ; set maximum instantaneous speed changes (mm/min)
                                    M566 X600 Y360 Z24 E1200                                   ; in mm/min-Marlin values
                                    ;M203 X9000 Y9000 Z180 E1200                                ; set maximum speeds (mm/min)
                                    M203 X6000 Y6000 Z1200 E4800                               ; set maximum speeds-Marlin values transform to mm/m
                                    ;M201 X1000 Y800 Z250 E250                                  ; set accelerations (mm/s^2)
                                    M201 X350 Y350 Z50 E30000                                  ; set accelerations-Marlin values
                                    M906 X1100 Y1100 Z1100 E1100 I30                           ; set motor currents (mA) and motor idle factor in per cent
                                    M208 X-6.0 Y-9.0 Z-20 S1                                   ; set axis minima
                                    M208 X400 Y400 Z445 S0                                     ; set axis maxima-need to remeasure this
                                    M671 X-40:440 Y200:200                                     ; leadscrews position at right and left of the X axis
                                    M574 X1 S1 P"!io0.in"                                      ; configure active-high endstop for low end on X via pin io0.in
                                    M574 Y1 S1 P"!io1.in"                                      ; configure active-high endstop for low end on Y via pin io1.in
                                    ;M574 Z1 S1 P"io2.in+io3.in"                               ; configure active-high endstop for low end on Z via pin-for original endstop's
                                    M574 Z1 S2                                                 ; endstop set to z-probe
                                    ;Stall Detection
                                    ;M915 P0 S-5 F0 H200 R0                                    ; P=drive motor , S= sensitivite , H=motorstep/sec ( check home file)
                                    M950 S0 C"io5.out"                                         ; create servo pin 0 for BLTouch
                                    M558 P9 C"^io5.in" H5 F60 T6000 R0.2 A10                   ; set Z probe type to bltouch and the dive height + speeds
                                    G31 P25 X41.13 Y2.69 Z1.537                                ; set Z probe trigger value, offset and trigger height
                                    M557 X40:400 Y0:400 S72:80                                 ; define mesh grid
                                    ; Piezo Z-probe
                                    ;M558 P8 C"io5.in" I1 R0.4 F300 X0 Y0 Z1                   ;new piezo
                                    ;G31 X0 Y0 Z-0.1 P100                                      ;new piezo
                                    M307 H0 R0.286 C453.000:453.000 D1.10 S0.50 V24.0 B0       ; disable bang-bang mode for the bed heater and set PWM limit
                                    M143 H0 S120                                               ; set temperature limit for heater 0 to 120C
                                    M307 H1 R1.840 C275.300:275.300 D4.10 S0.50 V24.0 B0       ; disable bang-bang mode for heater  and set PWM limit
                                    M143 H1 S285                                               ; set temperature limit for heater 1 to 285C
                                    M950 F0 C"out4" Q25000                                     ; create fan 0 on pin out4 and set its frequency
                                    M106 P0 S0 H1 T45                                          ; set fan 0 value. Thermostatic control is turned on
                                    M950 F1 C"out5" Q25000                                     ; create fan 1 on pin out5 and set its frequency
                                    M106 P1 S0 H1 T45                                          ; set fan 1 value. Thermostatic control is turned on
                                    M950 F2 C"out7" Q25000                                     ; create fan 2 on pin out7 and set its frequency
                                    M106 P2 S0 H-1                                             ; set fan 2 value. Thermostatic control is turned off
                                    ;M950 F3 C"out8" Q500                                      ; create fan 3 on pin out8 and set its frequency
                                    ;M106 P3 S0 H-1                                            ; set fan 3 value. Thermostatic control is turned off
                                    M563 P0 D0 H1 F0:2                                         ; define tool 0
                                    G10 P0 X-6.0 Y-7.0 Z0                                      ; set tool 0 axis offsets
                                    G10 P0 R0 S0                                               ; set initial tool 0 active and standby temperatures to 0C
                                    M572 D0.4 S0.05
                                    ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
                                    ;M564 H0                                                   ; moving axes before/without homing
                                    ;M591 P1 C"io4.in" S1 D0                                   ; filament run out sensor - work in progress
                                    M308 and M950 are not on the same order. Not sure how important is
                                    • tpyoknigundefined
                                      tpyoknig @razrudy
                                      @razrudy I don't think this is config related as replacing my config with a default one, or not one at all the same behavior exists.
                                      @fcwilt I don't know. Could that be related to the fuse that I replaced that was loose at the start that was causing the bed to power on and off randomly? Or something else?
                                      • razrudyundefined
                                        razrudy @fcwilt
                                        @fcwilt said in Duet 3 6HC Output_0 always on:
                                        Separate PSU for bed. Is there any other way to control the mosfet?
                                        • fcwiltundefined
                                          fcwilt @razrudy
                                          The 6HC has the separate power input for OUT 0. If the current rating of OUT 0 is adequate you can connect the bed power supply to OUT 0 POWER IN and the bed directly to OUT 0.
                                          Just verify that the grounds of both power supplies are connected together if the two board ground connections are not.
                                          • tpyoknigundefined
                                            tpyoknig
                                            I've tried this with seperate supplies, the same supply and new power supplies to no change in the problem I'm experiencing so I don't think it's related to the power suppl(y/ies).
