    Need Insight! Y Axis Jumping - Cannot Find Cause
    • Shanian79undefined
      Shanian79
      Looking for some insight and help with this. It's driving me mad! Photos, config and M122 listed below.
      I have 6 identical machines all running the exact same hardware, config and Duet2Wifi boards on 3.2.2. RR3 and DWC
      One of them keeps jumping on the Y axis at the same height for any model/print file. I have gone through and eliminated all physical possibilities, replaced the belt and stepper just incase there was something that was not visible, wiped the Duet and re-loaded all firmware.
      I don't believe its a slicer (Simplify3D) issue as the same model file prints normally on the other machines.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N85S4-7J1FG-3SJ6P-KB9ZR
      Used output buffers: 3 of 24 (24 max)
      Static ram: 23460
      Dynamic ram: 73944 of which 132 recycled
      Never used RAM 14544, free system stack 99 words
      Tasks: NETWORK(ready,182) HEAT(blocked,150) MAIN(running,418) IDLE(ready,20)
      Owned mutexes:
      Last reset 26:55:40 ago, cause: software
      Last software reset at 2021-03-08 09:18, reason: User, GCodes spinning, available RAM 14544, slot 1
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU temperature: min 15.3, current 23.5, max 25.4
      Supply voltage: min 21.9, current 22.4, max 22.8, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max 0/280
      Driver 1: position 800, standstill, SG min/max 0/296
      Driver 2: position 5498, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max 0/1023
      Driver 5: position 0
      Driver 6: position 0
      Driver 7: position 0
      Driver 8: position 0
      Driver 9: position 0
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-03-09 12:14:29
      Slowest loop: 251.86ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.7ms, write time 144.4ms, max retries 0
      DMs created 83, maxWait 10720108ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 82007, completed moves 82007, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.6
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 253.46ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address f4:cf:a2:6e:7e:9d
        WiFi Vcc 3.37, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 21080
        WiFi IP address 192.168.4.125
        WiFi signal strength -49dBm, mode none, reconnections 0, sleep mode modem
        Clock register ffffffff
        === Filament sensors ===
        Extruder 0: pos -3.02, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      CONFIG
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 21 2020 09:47:23 GMT-0600 (Central Standard Time)
      M550 P"Ender C2" ; set printer name
      M575 P1 S1 B57600
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P3 S1 ; physical drive 3 goes backwards
      M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Set idle timeout
      M208 X235 Y235 Z260 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X10 Y5 Z1.1
      ; set Z probe trigger value, offset and trigger height
      M557 X20:210 Y20:210 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q10 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q10 ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q10 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
      G10 P0 X0 Y-10 Z0 ; set tool 0 axis offsets
      M591 P1 C"xstop" S1
      M501
      M591 D0 P5 C"e0_stop" R1:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 140%, 3mm comparison length, disabled
      • Vetiundefined
        Veti
        @Shanian79 said in Need Insight! Y Axis Jumping - Cannot Find Cause:
        next thing to rule out is a bad driver.
        change to
        M584 X0 Y4 Z2 E3 ; set drive mapping
        and move the y connector to e1
