    Endstop pin state
    Using Duet Controllers
    • nikosundefined
      nikos
      I made machne that moves two sets of valves controled by duet2wifi . And I have problem with moving axes.
      I need to move axes from one endstop too another. Axes moves only in two position but I need to be sure that it reaches it and after power up, know in what position it is. Thats why I mounted two mechanical endstops.
      My problem is that I cant configure this second endstop.
      First thought was to make trigger. unfortunately G1 moves are stored in buffer and need to be finished before trigger.
      I serched for g/m code for imidately terminated moves but unfortunately I didnt find one. Only m112 but it shoot down duet too.
      I was thinking to make a small loop witch move axes for about 0,5mm but before each move check state on endstop pin. I know that duet with meta commands should do this but unfortunately I dont Know how.
      I can make loop and it work fine but when I add condition for checking a pin state It dosent work.
      I make input Pin with m950 and check state with m409 but it don't change value when I use endstop.
      For checking I use:
      M950 J1 C"^e0stop"
      M409 K"sensors.gpIn[1].value" or "m409 K"state.gpIn[1].value"
      At this point I use M574 for change endstop pin for axes when moving. But after power up duet don't know axes position before power off. I know that I can use m911 too save state on power loss but hopping that I will be able to configure it depends on pin state. It will open up for me whole new way to use Duet.
        jay_s_uk
        if you are just moving from on to the other why not just do it as a homing move?
        so for min
        M574 U1 S1 P"whatever"
        G1 H1 U-400
        then for max
        M574 U2 S1 P"whatever"
        G1 H1 U400
        Although you can only have one endstop at a time for each axis, theres nothing stopping you from reconfiguring it before a move
        You could also use a G38.2 probing move
        nikosundefined 1 Reply Last reply Reply Quote 0
        • nikosundefined
          nikos @jay_s_uk
          @jay_s_uk Your solution is the way it works right now. But when I will be able to configure it with simple logic it will allow me make it full independent from user.
