    DRV8825 Motor Whining (RADDS)
    • Bobbyofna
      Bobbyofna last edited by
      Hello, I am new to RFF and am trying to install RRF on my custom designed IDEX 3D Printer. All of the motors are using the RAPS128 driver except for the extruders, which are using drv8825 stepper drivers. The two motors using the drv8825 drivers make a high pitched noise and dont move when i send the command for them to move. I have the things on the bottom of RADDS properly set for 1/32nd stepping, and I have checked all of the connections. The motors work with raps but not with the drv8825 driver. All motor currents are properly set for the current rating of the motor. I believe the issue lies in the configuration but im not totally sure. Are the drv8825 drivers compatible with radds and RRF in the first place. I have attached my config.g for reference. Thanks!
      [[language]]
      ; Movement section
      M569 P0 S0 R1                          	; Drive 0 goes forwards (change to S0 to reverse it)
      M569 P1 S0 R1                         	; Drive 1 goes forwards
      M569 P2 S1 R1                         	; Drive 2 goes forwards
      M569 P3 S1 R1                         	; Drive 3 goes forwards
      M569 P4 S1 T2							; Drive 4 goes forwards
      M569 P5 S1 T2                         	; Drive 5 goes forwards
      M584 X0 Y1 Z2 U3 E4:5               	; Create U axis for second X carriage before we try to configure it
      M574 X1 Y1 U2 Z0 S0                 	; Set endstop configuration (X and Y endstops at low end, U endstop at high end, active high, no Z endstop)
      M201 X1500 Y1500 U1500 Z15 E10000      	; Accelerations (mm/s^2)
      M203 X15000 Y15000 U15000 Z100 E3600	; Maximum speeds (mm/min)
      M566 X6000 Y6000 U6000 Z300 E3000     	; Minimum speeds mm/minute
      M208 X170 Y235 U240 Z200				; set axis maxima (adjust to suit your machine)
      M208 X-45 Y-15 U25 Z-0.2 S1				; set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
      M92 X640 Y1280 U1280 Z800				; Set axis steps/mm
      M92 E775:775                       		; Set extruder steps per mm
      G21                                 	; Work in millimetres
      G90                                 	; Send absolute coordinates...
      M83                                 	; ...but relative extruder moves
      ; Z probe section
      M558 P1 X0 Y0 Z1 H3 F20 T3600			; Smart IR Z probe, used for homing Z axis, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
      G31 X15 Y35 Z1 P500           			; Set the probe height and threshold (put your own values here)
      ; Heater and thermistor section
      M305 P0 T100000 R4700 H0 L0				; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 R4700 H0 L0				; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
      M305 P2 T4700 R4700 H0 L0				; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
      M301 H1 P10 I0.10 D100 T0.50 S1.0		; PID settings for extruder 0
      M301 H2 P10 I0.10 D100 T0.50 S1.0		; PID settings for extruder 1
      M570 S120								; Increase to allow extra heating time if needed
      ; Tool definition section
      M563 P0 D0 H1 F1                       	; Define tool 0 to use extruder drive 0 and heater 1
      M563 P1 D1 H2 X3 F2                    	; Define tool 1 to use extruder drive 1 and heater 2
      G10 P0 X0 Y0 Z0 S0 R0      				; set tool 0 offsets and temperatures
      G10 P1 Y0 U0 Z0 S0 R0      				; set tool 1 offsets and temperatures
        I can't comment on the compatibility of DRV8825 with RADDS, but your E acceleration is 10000 which is very high. Try 1000.
