    auto update of probe height
    Gcode meta commands
    • appjawsundefined
      appjaws
      I have a macro that probes 10 times so that the user can update G31 with the average probe height.
      The macro now calculates the average probe height but I don't know how to update G31 permanently from within the macro.
      My current G31 X-25 Y-5 Z0.67 P500 needs to be amended to be G31 X-25 Y-5 Z(average value) P500
      Any ideas on how to do this?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • oliofundefined
        oliof
        Checking the object model, it looks like the median value spit out from the G30 S-1 runs is not available. But sensors.probes[0].lastStopHeight is. So with the variables that landed in 3.3b2, you might be able to read that after each individual probing run, and then in the end build your own median or average from the measurements.
        Untested code that will most certainly not work (I don't have a standalone machine with 3.3b2 at hand to test), assuming a single probe:
        stop_heights = 0.0
        while iterations < 30
          G30 P{iterations} X0 Y0 Z-99999
          stop_heights = stop_heights + sensors.probes[0].lastStopHeight
        G30 P31 X0 Y0 Z-9999  S-1
        avg_heights = stop_heights_sum/32  ; iterations starts at 0
        G31 X-25 Y-5 Z{avg_heights} P500
          I feel like M500 P31 and G30 S-3 could probably come into play here, but I'm not if that's needed now that conditional is available.
          https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M500_Store_parameters
          If the P31 parameter is used, the G31 trigger height, trigger value and X and Y offsets for each possible Z probe type (in older firmware versions the G31 parameters are stored even if the P31 parameter is not present)
          https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G30_Single_Z_Probe
          G30 S-3 ; Probe the bed and set the Z probe trigger height to the height it stopped at (supported in RRF 2.03 and later)
          The downside of G30 S-3 is that it takes the singular result and not any average of several results.
