    Wrong values DHT22
    Beta Firmware
    476
    • Marco Bonaundefined
      Marco Bona
      Hello everybody,
      i have a little problem with the DHT22 sensor readings. After adding the humidity sensor I get readings from 2000/0 to 2000/2000. The sensor is connected to PT100 board on the spi.cs2 pin of the motherboard. I also tried to invert the pin but the values do not change. With arduino sensor works correctly, so I would rule out a defect on the sensor. I am currently using the 3.3 beta2 firmware, I can't say that it worked with a previous version because I just installed it.
      I enclose the relative configuration and the report.
      Any help is appreciated.
      Thank you
      M308 S10 P"0.spi.cs2" Y"dht22"       A"Chamb Temp"     ; define DHT22 temperature sensor
      M308 S11 P"S10.1"   Y"dhthumidity" A"Chamb Humid[%]" ; Attach DHT22 humidity sensor to secondary output of temperature sensor
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.3beta2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6JKF0-3S86T-9A5YD
      Used output buffers: 1 of 40 (22 max)
      Static ram: 148476
      Dynamic ram: 63220 of which 0 recycled
      Never used RAM 142496, free system stack 188 words
      Tasks: SENSORS(delaying,51) Linux(ready,145) HEAT(delaying,303) CanReceiv(notifyWait,798) CanSender(notifyWait,374) CanClock(delaying,341) TMC(notifyWait,91) MAIN(running,923) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 00:13:34 ago, cause: software
      Last software reset at 2021-03-13 13:52, reason: User, Move spinning, available RAM 142544, slot 1
      Software reset code 0x0004 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 21.7, current 22.3, max 22.5
      Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 0, standstill, reads 57687, writes 20 timeouts 0, SG min/max 0/0
      Driver 1: position 0, standstill, reads 57687, writes 20 timeouts 0, SG min/max 0/0
      Driver 2: position 0, standstill, reads 57689, writes 18 timeouts 0, SG min/max 0/0
      Driver 3: position 0, standstill, reads 57689, writes 18 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 57690, writes 17 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 57690, writes 17 timeouts 0, SG min/max 0/0
      Date/time: 2021-03-13 14:05:45
      Slowest loop: 2.13ms; fastest: 0.06ms
      === Storage ===
      Free file entries: 10
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 7337, send timeouts 0, received 9759, lost 0, longest wait 1ms for reply type 6042, peak Tx sync delay 255, free buffers 49 (min 48)
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 1ms ago
      RX/TX seq numbers: 30326/30326
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2d52c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3-b2
      Daemon:
      Finishing macro daemon.g, started by system
      > Next stack level
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 37.31
      Codes per second: 0.17
      Maximum length of RX/TX data transfers: 3836/840
      • A Former User?
        A Former User @Marco Bona
        @Marco-Bona
        Just the opinion of me as an avarage user: Would be good if you could try it first with the latest stable release to set up something new, to have a baseline to judge that it ever worked in the first place, which would be 3.2.2 and report back. Please also add a photo or schematic of your wiring, that would make assistance easier. Always a good thing is a screenshot from DWC of the sensor behaviour with a) printer idle b) printer printing would be great.
        Also if you have time I recall a post from not long ago with somebody having had all problems gone with an external 5V supply.
        @Marco-Bona
        Edit: Please add Board-type and Revision (e.g. duet2ethernt1.0.4 orwhatever you have)
        • pkosundefined
          pkos
          To be sure - you said after adding the humidity sensor - does this mean the temperature readings work?
          Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
            Marco Bona
            @LB,unfortunately now i'm printing and can't downgrade to firmware 3.2.2.
            I am attaching the image of the DWC screen and wiring (hope you can understand).
            When connected to arduino, the sensor worked well at both 3.3V and 5V. I also checked the voltage with a tester on the PT100 board output and it was correct.
            @pkos, I read the 2000 value on both temperature and humidity
              Marco Bona
              @LB , sorry, I did not indicate it because it is written in the diagnostics, however the board is duet3 MB6HC + expansion board 3HC.
              Due to limitations the sensor is installed on the motherboard.
              A Former User? pkosundefined 2 Replies Last reply Reply Quote 0
              • A Former User?
                This post is deleted!
                • pkosundefined
                  pkos @Marco Bona
                  @Marco-Bona I know this was an issue in 3.2 (I was one of those who reported the problem), but it's gone as of 3.2.2.
                  I am wondering how much the PT100 board impacts this though.
                  I also wonder if you can use regular inputs on a 6HC the way you would use them on a 3 mini 5+ - there's a thread about how to do it on the 3 mini somewhere here. Might help you out.
                    Marco Bona
                    @pkos, i read that post before posting the problem but i thought by 3.2.2 it was solved.Currently i was experimenting new functions, i hope in future @dc42 can solve
                    • pkosundefined
                      pkos
                      Out of curiosity - do you get the same if you disconnect the PT100 board and connect the DHT to the duet directly?
