    G30 Acting strange
    • Adamfilip
      Adamfilip last edited by
      I updated to the most recent firmware.
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Electronics: Duet WiFi 1.0
      Firmware Version: 1.19RC7 (2017-08-11)
      WiFi Server Version: 1.19beta10
      Web Interface Version: 1.19-RC1
      My Machine is a CoreXY that Homes to YMax, XMin, ZMin
      Made a few changes necessary for the new firmware (reverse y)
      If I home X & Y and then move to the middle of the bed.. and run a G30
      it doesnt just plunge and probe Z, it moves out of position.
      I have uploaded a video to help show the issue.
      https://youtu.be/Do2nWShjC84
      Here are my config.g
      [c]
      ; Configuration file for Duet WiFi
      ; generated by RepRapFirmware Configuration Tool on Sun Oct 23 2016 10:30:40 GMT-0400 (Eastern Standard Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M555 P2 ; Set firmware compatibility to look like marlin
      M557 X20:260 Y0:240 S14 ; define a grid covering the XY area indicated with the specified grid spacing
      M376 H10 ; Taper grid after 10mm
      M667 S1 ; Select CoreXY mode
      M208 X280 Y250 Z300 S0 ; Set axis maxima
      M574 X1 S1 ; Reverse X endstop
      M574 Y2 S1 ; Y Max Stop
      ;M574 E0 S1 ; Endstop for Zprobe on E0
      M558 P4 X0 Y0 Z1 H4 F120 T6000 I1 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z-1.15 ; Set Z probe trigger value, offset and trigger height
      M581 E1 T1 ; Set Filament Sentinel to trigger and Pause print, if filament runs out
      M569 P0 S0 ; Drive X goes backwards
      M569 P1 S0 ; Drive Y goes backwards
      M569 P2 S0 ; Drive Z goes forwards
      M569 P3 S0 ; Drive E3D Titan goes backwards
      M92 X200 Y200 Z800 E418.5 ; Set steps per mm
      M566 X800 Y800 Z20 E800 ; Set maximum instantaneous speed changes (mm/min)
      M203 X12000 Y12000 Z1500 E1800 ; Set maximum speeds (mm/min)
      M201 X2000 Y2000 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1200 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S280 ; Set maximum heater temperature to 280C
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B4138 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
      M305 P1 X200
      M563 P0 D0 H1 ; Define tool 0
      G10 P0 X0 Y0 ; Set tool 0 axis offsets
      M550 PTitanXY ; Set machine name
      M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
      [/c]
      Here is my Home All.
      [c]
      ; homeall.g
      ; called to home all axes
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z5 F6000
      G90
      ; Move towards X and Y axis endstops (first pass)
      G91
      G1 X-385 F2600 S1
      G1 Y385 F2600 S1
      G90
      ; Go back a few mm
      G91
      G1 X5 F6000
      G1 Y-5 F6000
      G90
      ; Move slowly to axis endstops once more (second pass)
      G91
      G1 X-285 F360 S1
      G1 Y285 F360 S1
      G90
      G91 ; relative mode
      G1 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
      G90 ; back to absolute mode
      G1 X140 Y140 F2000 ; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height
      [/c]
      • deckingman
        deckingman last edited by
        Yup. You haven't done everything according to the release notes. I know this because I did exactly the same as you. The latest firmware runs deploy probe and retract probe if those files are present. You need to delete them from .sys.
        • Adamfilip
          That worked. totally missed it in the notes.. thank you!!
          • deckingman
            Thanks but if I were awesome, I'd have read the release notes and not made the same mistake, which is the only reason I knew what the problem was. Anyway, glad you are sorted.
