    Duet 2 WiFi: No WiFi interface available
    • TheMutluundefined
      TheMutlu
      got a new Duet 2 Wifi which I wanted to set up.
      However, it returns "No WiFi interface available" on M587.
      I also tried:
      M115: "FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-02-09b1"
      And M122 which does not return anything and requires a reconnect to the Duet.
      Reinstalling the Firmware of the Duet and the WiFi Module did not change the behavior.
      Looking at the board it seems as if a connection on the WiFi Module is not properly soldered, but I have no experience with that:
      I'm thankful for any Input!
        droftarts administrators @TheMutlu
        @TheMutlu yes, that looks like poor soldering on the WiFi module, so it’s not even turning on, so your Duet is identifying as an Ethernet model! Please contact the vendor, initiate a warranty replacement following their process, and refer to this thread for approval.
