Solved Duet 3 6ch not recognized after installing Beta version
@UcantCNCme said in Duet 3 6ch not recognized after installing Beta version:
just checked the config file and its still reading 3.2.3,
Where are you seeing that? Sounds like maybe just the text in the config file saying what version of the config tool was used to generate the file.
To see what version is installed either send M115 and it will tell you, or check the settings and machine specific tab in DWC to see the firmware and DWC versions installed.
apologies your right, that m,st of been the version during the config, heres the M115
3/15/2021, 10:15:36 PM M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-02-11 -
Ok, that's makes more sense.
The config file text won't change unless you change it. It's just a text file after all.
ah right, good to know, thank you very much for your help. i need to start another thread regarding my XYZ touch probe now, hopefully i can get this thing up and running!
