    New hotend fan
    Duet Web Control
    587
    • PRIOR123undefined
      PRIOR123
      Hi All,
      I have just installed a new Noctua fan for my ender 3 using the duet wifi 2. It's all gone pretty smoothly up til now. I have put the plug into FAN1 which goes into a buck converter reducing it down to 12V then to the fan. however, FAN1 is set to come on at 45degree which doesn't seem to be happening.
      I thought it may be because my wiring was poor or the buck converter was the issue, so I plugged my spare 5015 blower directly into the 24V FAN1 plug. which even when the hotend gets above 45 degrees isn't turning on. Can someone help? config.g is below
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 13:09:04 GMT-0600 (Central Standard Time)
      M550 P"Jack's Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S1 ; physical drive 0 goes backwards
      M569 P1 S1 ; physical drive 1 goes backwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M350 X16 Y16 Z16 E16 I1 ;a configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 S1 ;set axis minima NEW 22.09.2020
      M208 X230 Y220 S0 ;set axis maxima NEW 22.09.2020
      ;M208 X-5.5 Y-10 Z0 S1 ; set axis minima
      ;M208 X220 Y220 Z250 S0 ; set axis maxima
      ;M208 X-5.5:220 Y-10:220 Z0:250 ; set axis minima and maxima NEW ADDED 22.09.2020
      M574 X1 S1 P"X Stop" ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"Y Stop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      G31 X-10 Y-20 Z0.5 ; set Z probe trigger value, offset and trigger height NEW 22.09.2020
      M557 X30:215 Y0:200 P6 ; define mesh grid NEW 22.09.2020
      ;G31 P500 X-31 Y20 Z0.5 ; set Z probe trigger value, offset and trigger height
      ;M557 X5:185 Y5:205 P6 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
      M106 P1 S1 H1 T45 C"Hotend Fan" ; Set fan 1 (Hotend fan) Thermostatic control. Turns on when hotend reaches 45c
      M106 P0 S0 H-1 B0.5 C"Part Cooling" ; Set fan 0 (Part cooling blower) G-code controlled. Thermostatic control is turned off
      M106 P2 C"Board Cooling" S1 ; set fan 2 name and value. Thermostatic control is turned on
      M563 P0 S"Extruder 01" D0 H1 F0 ; define tool 0
      T0 ; select first tool
      Also if someone can tell me how I put this into the standard black box that everyone else seems to be able to display the config.g in i repost as I'm sure it way easier to read
      Any help much appreciated
      • Vetiundefined
        Veti
        @PRIOR123 said in New hotend fan:
        the important thing is how you wired the negative terminal. if you connected that to the buck converter you can actually damage the duet. the buck converter is not mean to run on pwm.
        • Vetiundefined
          Veti
          this is how you should wire the buck converter
          https://www.blvprojects.com/blv-mgn-cube-3d-printer?pgid=k8hkwn62-378a696b-a7f1-46b5-9e6c-1290261fa468
            https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
            • PRIOR123undefined
              PRIOR123
              Thanks Both!, I've currently moved it to the always-on point because I thought it no longer matters because the fans are silent. but I would like to use this properly. Though like Veti has said I have a bad feeling that I have damaged the board. if you can you are able to advise how I can test if I have this that would be a huge help.
              But thanks for the links, i thought i was going to need a buck converter per fan the way i was wiring it. This makes it MUCH more efficient!
                If you've verified that the fan is working when connected directly to vin or an always on fan terminal, then you can test it on each fan port by itself sending M106 P0 H-1 S1 to enable fan0 port at full speed. P1 for fan1 port, P2 for fan2 port.
                There's always the chance that a fan mosfet has been damaged.
                Do you see any damage to the tiny chips near the fan port?
                https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
                PRIOR123undefined 1 Reply Last reply Reply Quote 0
                • PRIOR123undefined
                  PRIOR123 @Phaedrux
                  @Phaedrux Soo this issue has now got a little bigger. I tried M106 P0 H-1 S1 and the 5015 blower worked fine and there weren't any other fans plugged in at the time. I then put one of the new fans in and it wasn't happy at all and the entire board went funny like it was shorting. so I turned all power off, now it doesn't seem to like the fuses, I have changed them a couple of times even though they have NOT blown. it seems that when this 'short' happens I need to wobble/remove and reinstall the fuses and everything is fine again. I now think it could be down to a bad earth point. I have checked the PSU and it's fine. But when I try and test the earth pin on the plug and the chassis of the ender 3 there is no noise on my multimeter. Is there a separate earth point for the duet board? in my head, it would seem unusual to have this but I'm not an electrical/electronic engineer. Any ideas?
                  Also I did check the mosfets and everything looks fine I will upload a picture in a minute
                  • PRIOR123undefined
                    PRIOR123
                    This post is deleted!
                    • PRIOR123undefined
                      PRIOR123
                        That looks like a blown mosfet.
                        • PRIOR123undefined
                          PRIOR123 @Phaedrux
                          @Phaedrux oh haha, pardon my ignorance but what does that mean? is it repairable? is it the reason for all my current issues?
                            droftarts administrators @PRIOR123
                            A MOSFET is an electronically controlled switch. Basically, it's what turns the fan output on and off. Yours has exploded, and the most likely reason is that the voltage was reversed when you connected the fan or buck converter. Note that this is the FAN2 MOSFET, marked TR1. The FAN0 and FAN1 MOSFETs (TR5 and TR9) look okay (but may not be).
                            is it repairable?
                            Yes, but you'll need some specialist equipment. See https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
                            There are a number of forum members that offer repair services, depending on your location: https://forum.duet3d.com/topic/13875/community-repairs
                            Related to Duet, most likely (less so other personal issues!). It's possibly failed shorted, or partially shorted. Removing the MOSFET may cure this (though leaves the FAN2 output inoperable), hard to say.
