fused fan?
I have a 1.04 board and have managed to short Fan0.
I'm swapping from 24v to 12v and think I bridged the two fan pins with the fan negative wire.I now have a 12v buck powering the fan and its refusing to start with fan neg connected the the pin in the image below
M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 X204 ; set fan 0 value. Thermostatic control is turned off
I can see there is a 1a blade fuse for the fans, but this isn't blown, and assume it protects the 24v +?
Check the fan mosfets for signs of damage.
https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
That's exactly the issue. Thank you!
