Error following update
  • Good evening,
    Following my many problems of setting, I wanted to make the update in 1.19,
    But as a misfortune never happens alone I made a mistake, I downloaded the .bin from the web interface and instead of refusing the installation I accept ,,,
    So my DUET WIFI does not want to connect on my wifi, I have good hand via PONTERFACE, but impossible to start the wifi via command M552 S1,
    I run M122 this is what it shows me.
    **>>> M552 S0
    SENDING:M552 S0
    WiFi module started
    Error: Failed to initialise WiFi module, code -10
    [ERROR] Error: Failed to initialise WiFi module, code -10
    M552 S1
    SENDING:M552 S1
    WiFi module started
    M122
    SENDING:M122
    Used output buffers: 1 of 32 (14 max)
    RepRapFirmware for Duet WiFi version 1.19beta11 running on Duet WiFi 1.0
    Board ID: 08DDM-9FAM2-LW4SD-6J9FL-3SJ6J-KJZ7Y
    Static ram used: 21132
    Dynamic ram used: 96292
    Recycled dynamic ram: 1360
    Stack ram used: 4008 current, 5316 maximum
    Never used ram: 6972
    Last reset 00:03:25 ago, cause: power up
    Last software reset reason: User, spinning module GCodes, available RAM 6972 bytes (slot 0)
    Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    [ERROR] Error status: 0
    Free file entries: 10
    MCU temperature: min 30.7, current 31.8, max 32.6
    Supply voltage: min 0.4, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0
    Driver 0: ok
    Driver 1: ok
    Driver 2: ok
    Driver 3: ok
    Driver 4: ok
    Slowest main loop (seconds): 0.100082; fastest: 0.000031
    MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Bed heater = 0, chamber heater = -1
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    Network state is disabled
    WiFi module is disabled
    HTTP sessions: 0 of 8
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)**
    If someone has an idea.
    thanks in advance
    Put the SD card in a PC, copy DuetWiFiServer-1.19.bin into it and rename it to exactly DuetWiFiServer.bin. Safely remove the card from the PC, put it back in the Duet. Restart the Duet and run M997 S1 to install it. When the blue led on the WiFi module stops flashing, run your macro to set the access point details.
  • He replies that:
    SENDING: M997 S1
    File DuetWiFiServer.bin not found
    I should have said you need to put that file in the /sys folder on the card.
  • Yes it is well here that I put the file
    Did you either restart the Duet or send M21 after you put the SD card back in?
    Are you sure its name matches exactly the name it says it can't find?
  • No I did not restart or made M21, must I do it.
    Yes the filename is the same. Can we do a hard reset on this card?
    Thank you for your patient
    You can do a hard reset by pressing the reset button (don't press the erase button by mistake!). Or you can send M999.
  • Hi, I also upgraded my firmware, then ran into issues regarding the wifi module. So I DL the DuetWiFiServer-1.19.bin file and renamed it to DuetWiFiServer.bin
    It wrote the firmware successfull but still I'm not able to start wifi module. Here is a log from pronterface. I have also tried restarting the duet wifi after firmware upgrade.
    Connecting...
    Printer is now online.
    >>> M997 S1
    SENDING:M997 S1
    Trying to connect at 460800 baud:
     success
    Erasing 290848 bytes...
    Uploading file...
    5% complete
    10% complete
    15% complete
    20% complete
    25% complete
    30% complete
    35% complete
    40% complete
    45% complete
    50% complete
    55% complete
    60% complete
    65% complete
    70% complete
    75% complete
    80% complete
    85% complete
    90% complete
    95% complete
    Upload successful
    WiFi module started
    >>> M552 S1
    SENDING:M552 S1
    WiFi module started
    EDIT:
    Hm, seems like it didnt upgrade the wifi firmware, shouldn't it be 1.19?
    M115
    SENDING:M115
    FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-08-14
    Running the firmware upgrade routine again won't change from 1.0 to 1.19 wifi firmware.
    EDIT! For anyone else just seeing this post, read this page: https://duet3d.com/wiki/Upgrading_to_DuetWiFiFirmware_1.19
    Solved all my issues! šŸ™‚ Do EXACTLY as it says.
  • HELLO,
    It shows me this message is normal?
    SENDING: M999
    [ERROR] Can not read from printer (disconnected?) (SerialException): call to ClearCommError failed
    Exception in thread Thread-15:
    Traceback (most recent call last):
    File "threading.pyc", line 808, in __bootstrap_inner
    File "threading.pyc", line 761, in run
    File "printrun \ printcore.pyc", line 357, in _sender
    File "printrun \ printcore.pyc", line 623, in _send
    File "encodings \ utf_8.pyc", line 16, in decode
    UnicodeDecodeError: 'utf8' codec can not decode byte 0xe9 in position 33: invalid continuation byte
  • Well I move slowly,
    Now I just have a problem with the SetNetwork macro when I get to this step: M587 S "your-network-ssid" P "your-network-password". I therefore replace the non of my network between the "….." and the password of it between the "....." which gives the code:
    M587 S "...." P "...."
    I make the command and I have the error:
    Unsupported command: M857 S "...." P "....."
    Is something wrong?
    Thank you
  • you seem to have a typo make sure the command you are sending is indeed M587 your error looks like you are send M857?
  • Thank you
    yes that's right, but it's been 3 days that I try to advance with this printer so I'm starting to be tired.
    Ā  The map to find my network wifi:
    Ā  >>> M587
    SENDING: M587
    Remembered networks:
    LIVEBOX-2AF2
    But if I want to connect to it with the command M552 S1 it returns the following error message:
    M552 S1
    SENDING: M552 S1
    WiFi reported error: no known networks found
    Wifi module is idle
    When I reconnect on PONTERFACE I have this message: Connecting ...
    Wifi module is idle
    Do you have an idea ?
    Thank yo
    It probably means that you didn't send the M587 command to store the SSID and password details correctly. You can send M587 with no parameters to get a list of SSIDS that have been stored.
    Instead of send the M587 command from a macro, you can also use a terminal emulator. Under Windows I use YAT, https://sourceforge.net/projects/y-a-terminal/. You can't use Pronterface, Repetier etc. because they will convert the lower case characters in your password to uppercase.
  • @dc42:
    Thanks to all, it's back again.
    Thank you for your patient.
    It is necessary to use YAT
