    Duet wifi 2 connection issue
    Using Duet Controllers
    • ncundefined
      nc
      I connected my duet 2 wifi to my network and was able to access DWC while it was powered over usb. I then connected my 3d printer hardware and my duet would no longer connect to my network. I tried forgetting and re entering my network credentials but the board won't reconnect and the wifi led flashes. Any idea why this is?
        When you are connected to VIN, also connect via USB so you can send terminal commands and see what is happening. Be careful when connecting via USB while also connecting via VIN though to avoid USB ground loops. Use a laptop on battery power to be safe, or at least ensure that the PC and printer are on the same outlet.
        From the terminal send M552 and see what it responds with.
        Cycle through the network commands and see what it says for each.
        M552 S-1
        M552 S0
        M552 S1
        M587
