    Extruder driver always stops/resets at same location
    • TechNiundefined
      TechNi
      I have a very strange problem. I'm trying to print a Benchy but somehow the extruder motor always stops working at the exact same location. tried with both Cura and PrusaSlicer. Same problem, just different location. So when the motor stops, I can't even make it turn anymore via the Web Control. No error message, nothing. The print continues as normal, heater works fine too but the motor won't turn anymore. I have to reset the Duet 3. And then it works fine again. No clogging or anything. I assume the driver decided to reset mid print.
      But first a few information about the printer:
      • Duet 3 6HC
      • RRF 3.2
      • IDEX with Markforged kinematics (like the Haq XY)
      • Bondtech BMG Extruder
      • Hotend Copperhead
      • Extruder Motor Nema 17 42x42x20
      • PSU Mean Well RSP-500-24
      • config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Jan 22 2021 17:41:49 GMT+0100 (Central European Standard Time)
      G90                                                     ; send absolute coordinates...
      M83                                                     ; ...but relative extruder moves
      M550 P"MyPrinter"                                       ; set printer name
      ;M669 K1                                                ; select CoreXY mode
      M669 X1:1:0:1                                           ;
      M669 Y0:-1:0:0                                          ;
      M669 Z0:0:1:0                                           ;
      M669 A0:0:0:1                                           ;
      M569 P0.0 S1                                            ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                            ; physical drive 0.1 goes forwards
      M569 P0.2 S0                                            ; physical drive 0.2 goes forwards
      M569 P0.3 S0                                            ; physical drive 0.3 goes forwards
      M569 P0.4 S0                                            ; physical drive 0.4 goes forwards
      M569 P0.5 S1                                            ; physical drive 0.5 goes forwards
      M584 X0.0 Y0.1 Z0.2 A0.3 E0.4:0.5                       ; set drive mapping
      M915 X Y Z A S5 R2										; Motor stall detection
      M350 X16 Y16 Z16 A16 E16:16 I1                           			; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1066.67 A80.00 E415.00:415.00        		  	; set steps per mm
      M566 X300.00 Y300.00 Z120.00 A300.00 E120.00:120.00       			; set maximum instantaneous speed changes (mm/min)
      M203 X8400.00 Y8400.00 Z750.00 A8400.00 E1200.00:1200.00 			; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z40.00 A1000.00 E250.00:250.00     			; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1400 A1000 E1000:1000 I30             		 	; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                 			; Set idle timeout
      M208 X-283 Y-198 Z0 A-256.2 S1                                  	; set axis minima
      M208 X222 Y251 Z390 A194 S0                                  		; set axis maxima
      M574 X2 S1 P"!io0.in"									; Endstop X-Axis high end microswitch-type
      M574 Y2 S1 P"!io1.in"									; Endstop Y-Axis high end microswitch-type
      M574 Z1 S2												; Endstop Z-Axis low end
      M574 A1 S1 P"!io3.in"									; Endstop A-Axis low end microswitch-type
      M558 A5 S0.03 P8 C"io2.in" H5 F120 T6000                ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X2 Y-22 Z1.5                                   ; set Z probe trigger value, offset and trigger height
      M557 X-150:150 Y-190:190 S60:76                         ; define mesh grid
      M308 S1 P"temp1" Y"pt1000" R2200      			; configure sensor 1 as PT1000 on pin temp1
      M950 H1 C"out1" T1                           	; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 R2.325 C143.1 D11.28 S1.00 V23.9 B0		; disable bang-bang mode for heater 1 and set PWM limit
      M143 H1 S280                                 	; set temperature limit for heater 1 to 280C
      M308 S2 P"temp2" Y"pt1000" R2200      			; configure sensor 2 as PT1000 on pin temp2
      M950 H2 C"out2" T2                           	; create nozzle heater output on out2 and map it to sensor 2
      M307 H2 R2.444 C136.0 D8.23 S1.00 V23.9 B0		; disable bang-bang mode for heater 2 and set PWM limit
      M143 H2 S280                                 	; set temperature limit for heater 2 to 280C
      ;    Blowers
      M950 F0 C"out7" Q500                                    ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out8" Q500                                    ; create fan 0 on pin out7 and set its frequency
      M106 P1 S0 H-1                                          ; set fan 0 value. Thermostatic control is turned off
      ;    Heatsink fans
      M950 F4 C"out4" Q500                                    ; create fan 1 on pin out4 and set its frequency
      M106 P4 S1 H1 T45                                       ; set fan 1 value. Thermostatic control is turned on
      M950 F5 C"out5" Q500                                    ; create fan 3 on pin out5 and set its frequency
      M106 P5 S1 H2 T45                                       ; set fan 3 value. Thermostatic control is turned on
      ; LEDs
      M950 F8 C"out3" Q500									; create LED on pin out3 and set its pwm frequency
      M106 P8 S0 H-1											; set LED value. Thermostatic control is turned off
      M563 P0 S"PH 1" D0 H1 F0                        		; define tool 0 (Print Head 1)
      G10 P0 X0 Y0 Z0	R0 S0                                   ; set tool 0 axis offsets
      M563 P1 S"PH 4" D1 H2 Y3 F1                        		; define tool 1 (Print Head 4)
      G10 P1 X0.2 Z0 A0 R0 S0   	                            ; set tool 1 axis offsets
      M563 P2 S"PH 1+4 D" D0:1 H1:2 Y1:3 F0:1 				; define tool 2 (Duplicate)
      G10 P2 X0 Y0 A200 S0 R0 								; set tool offsets and temperatures
      M567 P2 E1:1 											; set mix ratio 100% on both extruders
      M563 P3 S"PH 1+4 M" D0:1 H1:2 Y1:3 F0:1 				; define tool 3 (Mirror)
      G10 P3 X0 Y0 A0 S0 R0 									; set tool offsets and temperatures
      M567 P3 E1:1 											; set mix ratio 100% on both extruders
      ;M575 P1 S1 B57600                                       ; enable support for PanelDue
      T0 P0                                                   ; select first tool
      Both print heads are identical and strangely, the other print head has no problems printing the exact same G-code.
      Things I have already tried but didn't solve the problem:
      • Change the slicer (tested both Cura and PrusaSlicer)
      • Set retraction to 0.0
      • Connect extruder motor to different stepper driver
      • Changed the motor (identical one)
      • Increase the motor current from 1A to 1.2A
      • Run the print job without filament
      • Increased acceleration from 250 to 400 m/s^2
      • Touching the motor during print in order to do an electrostatic discharge (due to a similar problem reported here which reset the driver (kinda what I am experiencing))
      • Tried both absolute and relative extrusion
      • Tried different location on print bed (assuming there might be some sort of loose contact which resets the driver and which would be triggered at a different time then)
      • Disassembled whole print head checking for clogs or defects
      Here's the diagnostic (M122) both shortly before (a few sec) and after the incident. As you can see, the motion drivers (0-3) are still working but the extruder motor driver (DRIVER 4 or 5, dont remember which one since I swapped them at some point) already called it a day.
      BEFORE:
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956BA-NA3TJ-6JTDD-3SS6J-KUB2V
      Used output buffers: 1 of 40 (12 max)
      Static ram: 149788
      Dynamic ram: 63836 of which 64 recycled
      Never used RAM 145144, free system stack 124 words
      Tasks: Linux(ready,101) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1189) IDLE(ready,19)
      Owned mutexes: HTTP(MAIN)
      Last reset 00:04:36 ago, cause: power up
      Last software reset at 2021-02-01 20:51, reason: User, none spinning, available RAM 144936, slot 0
      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 3,3,3
      Aux1 errors 0,0,0
      MCU temperature: min 7.9, current 15.9, max 17.0
      Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: position 1642, standstill, reads 32301, writes 22 timeouts 0, SG min/max 0/1023
      Driver 1: position -18438, standstill, reads 32302, writes 22 timeouts 0, SG min/max 0/1023
      Driver 2: position 747, standstill, reads 32302, writes 22 timeouts 0, SG min/max 0/1023
      Driver 3: position -7345, ok, reads 32302, writes 22 timeouts 0, SG min/max 0/1023
      Driver 4: position 0, ok, reads 32307, writes 17 timeouts 0, SG min/max 0/107
      Driver 5: position 0, standstill, reads 32310, writes 14 timeouts 0, SG min/max 0/0
      Date/time: 2021-02-01 20:21:24
      Slowest loop: 160.84ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 113316ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 2149, completed moves 2101, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Heater 2 is on, I-accum = 0.7
      Segments left: 1
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is doing "G1 X28.612000 Y-115.767998 E0.007980" in state(s) 0
      USB is idle in state(s) 0
      Aux is assembling a command in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 1032, send timeouts 2414, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
      === SBC interface ===
      State: 4, failed transfers: 0
      Last transfer: 1ms ago
      RX/TX seq numbers: 10239/10239
      SPI underruns 0, overruns 0
      Number of disconnects: 0, IAP RAM available 0x2c8a8
      Buffer RX/TX: 240/1752-0
      === Duet Control Server ===
      Duet Control Server v3.2.0
      File:
      Buffered code: G1 X29.052 Y-115.920 E0.01170
      Buffered code: G1 X29.248 Y-115.912 E0.00828
      Buffered code: G1 X29.419 Y-115.853 E0.00759
      Buffered code: G1 X29.572 Y-115.764 E0.00748
      Buffered code: G1 X29.703 Y-115.637 E0.00768
      Buffered code: G1 X29.813 Y-115.489 E0.00778
      Buffered code: G1 X29.907 Y-115.295 E0.00907
      Buffered code: G1 X29.998 Y-114.955 E0.01484
      Buffered code: G1 X30.115 Y-114.723 E0.01096
      Buffered code: G1 X30.223 Y-114.991 E0.01219
      Buffered code: G1 X30.352 Y-114.905 E0.00651
      Buffered code: G1 X30.464 Y-115.337 E0.01880
      Buffered code: G1 X30.583 Y-115.547 E0.01015
      Buffered code: G1 X30.845 Y-115.794 E0.01520
      Buffered code: G1 X31.096 Y-115.908 E0.01160
      Buffered code: G1 X31.372 Y-115.903 E0.01164
      Buffered code: G1 X31.545 Y-115.836 E0.00781
      Buffered code: G1 X31.696 Y-115.738 E0.00760
      Buffered code: G1 X31.919 Y-115.499 E0.01374
      Buffered code: G1 X32.000 Y-115.142 E0.01545
      Buffered code: G1 X31.955 Y-114.710 E0.01828
      Buffered code: G1 X31.638 Y-114.122 E0.02816
      Buffered code: G1 X31.267 Y-113.510 E0.03014
      Buffered code: G1 X31.194 Y-113.290 E0.00978
      Buffered code: G1 X31.230 Y-113.148 E0.00619
      Buffered code: G1 X31.955 Y-111.937 E0.05947
      Buffered code: G1 X32.086 Y-111.577 E0.01616
      Buffered code: G1 X32.103 Y-111.274 E0.01277
      Buffered code: G1 X32.036 Y-110.986 E0.01247
      Buffered code: G1 X31.878 Y-110.750 E0.01198
      ==> 1412 bytes
      Pending code: G1 X31.655 Y-110.589 E0.01157
      Pending code: G1 X31.386 Y-110.504 E0.01191
      Code buffer space: 2344
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 39.76
      Maximum length of RX/TX data transfers: 3104/1316
      File /opt/dsf/sd/gcodes/HSM_3DBenchy_T1_PS.gcode is selected, processing
      AFTER:
      M122
      Static ram: 149788
      Tasks: Linux(ready,101) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1077) IDLE(ready,19)
      Last reset 00:05:24 ago, cause: power up
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 15.7, current 15.8, max 16.1
      Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 2312, ok, reads 62866, writes 0 timeouts 0, SG min/max 25/1023
      Driver 1: position -17768, ok, reads 62865, writes 0 timeouts 0, SG min/max 25/1023
      Driver 2: position 960, standstill, reads 62865, writes 0 timeouts 0, SG min/max 41/1023
      Driver 3: position -6196, ok, reads 62866, writes 0 timeouts 0, SG min/max 7/1023
      Driver 4: position 0, standstill, reads 62866, writes 0 timeouts 0, SG min/max 0/916
      Driver 5: position 0, standstill, reads 62866, writes 0 timeouts 0, SG min/max not available
      Date/time: 2021-02-01 20:22:12
      Slowest loop: 0.54ms; fastest: 0.05ms
      === Storage ===
      === MainDDARing ===
      Scheduled moves 2987, completed moves 2951, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === AuxDDARing ===
      Segments left: 1
      File* is doing "G1 X42.049999 Y-111.849998 E0.022950" in state(s) 0
      === CAN ===
      Messages queued 189, send timeouts 425, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
      RX/TX seq numbers: 12285/12285
      Buffer RX/TX: 192/1648-0
      File:
      Buffered code: G1 X42.050 Y-111.850 E0.02295
      Buffered code: G1 X41.634 Y-111.330 E0.02140
      Buffered code: G1 X41.232 Y-110.868 E0.01971
      Buffered code: G1 X40.759 Y-110.369 E0.02208
      Buffered code: G1 X40.213 Y-109.845 E0.02434
      Buffered code: G1 X39.739 Y-109.431 E0.02025
      Buffered code: G1 X39.247 Y-109.037 E0.02027
      Buffered code: G1 X38.633 Y-108.589 E0.02443
      Buffered code: G1 X37.994 Y-108.172 E0.02455
      Buffered code: G1 X37.444 Y-107.848 E0.02053
      Buffered code: G1 X36.509 Y-107.364 E0.03385
      Buffered code: G1 X35.564 Y-106.955 E0.03311
      Buffered code: G1 X34.672 Y-106.637 E0.03045
      Buffered code: G1 X33.712 Y-106.363 E0.03212
      Buffered code: G1 X32.742 Y-106.153 E0.03190
      Buffered code: G1 X31.798 Y-106.012 E0.03069
      Buffered code: G1 X30.903 Y-105.934 E0.02889
      Buffered code: G1 X29.960 Y-105.910 E0.03033
      Buffered code: G1 X29.078 Y-105.940 E0.02838
      Buffered code: G1 X5.654 Y-107.415 E0.75472
      Buffered code: G1 X5.312 Y-107.471 E0.01116
      Buffered code: G1 X5.113 Y-107.539 E0.00674
      Buffered code: G1 X4.931 Y-107.631 E0.00659
      Buffered code: G1 X4.678 Y-107.823 E0.01019
      Buffered code: G1 X4.543 Y-107.972 E0.00645
      Buffered code: G1 X4.427 Y-108.144 E0.00669
      Buffered code: G1 X4.334 Y-108.335 E0.00683
      Buffered code: G1 X4.266 Y-108.542 E0.00701
      Buffered code: G1 X4.213 Y-108.942 E0.01297
      Buffered code: G1 X4.543 Y-109.222 F6900.000
      Buffered code: G1 X10.573 Y-108.774
      ==> 1468 bytes
      Code buffer space: 2448
      Full transfers per second: 43.44
      The strange thing is there is no error message in the console at all. The good thing is the error happens quite early in the G-Code, so I can test a lot of things easily. The bad thing is, I am kinda running out of options.
      So I hoped that you guys might have a few ideas what else I could try.
      • TechNiundefined
        TechNi
        Also note that the faulty print head worked fine before and I already printed Benchy's with it. The problems arised after the hotend clogged a while ago (due to too high retraction settings) and I had to disassemble the print head.
        Here's also the G-Code for the Benchy. Since the problem always appears in the first layer (after the skirt), I shorted it a bit.
        3DBenchy_PrusaSlicer.gcode
          Most likely it's either a bad crimp on the extruder cable, or a bad output from the Duet. Try swapping the extruder motor connections where they plug into the Duet, and swap them in M584 too. Then see whether the fault stays with the extruder or with the driver.
          TechNiundefined 1 Reply Last reply Reply Quote 0
          • TechNiundefined
            TechNi @dc42
            @dc42 said in Extruder driver always stops/resets at same location:
            Thanks for the quick answer! I already tested the motor with both driver 4 and 5. And the other print head is also connected to one of these drivers but works fine. So I think we can rule out a faulty driver.
            But I will check the crimps again (already did a quick continuity test and they all seemed to work).
            • DocTruckerundefined
              DocTrucker
              Try sending M84 E0 E1 to the extruders when stucj and see if they start responding after? Long shot but I had a stubborn E drive after doing a dynamic swap and that is the bodge fix for my problem!
                Can you update to 3.2.2 by uploading this zip file to the system tab in DWC?
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                • TechNiundefined
                  TechNi
                  I checked the crimps, switched the drivers again, tried M84 (executes without error message but motor still doesnt respond after that) and also updated the firmware. Nothing. Problem still persisted.
                  Fortunately, I think I have found the problem and seems like it's the G-code which would be logical since the reset always happens at the exact same location in the G-code. And the reason for the "bad" G-code is an .stl file with a bad mesh. Funnily enough, it is one of the most downloaded files on thingiverse: the Benchy. After I fixed the mesh in PrusaSlicer, the Benchy printed just fine. The reason why this also happened in Cura is because I am not sure if Cura fixes the mesh sufficiently.
                  May it be possible that this is also a firmware problem? Considering how often the Benchy is printed with a faulty mesh and without mesh fixing, most firmwares probably still somehow manage to deal with this.
