Firmware 1.19 released
As some of you may have noticed, I have released firmware 1.19 for the Duet series. You can find it here https://github.com/dc42/RepRapFirmware/releases.
This release has taken much longer than originally planned, in part due to the number of OEM requests for feature additions that we had to satisfy. But I've also implemented some major items from the firmware wishlist; for example, bed levelling using multiple independent leadscrews, and resume-after-power-fail.
The plan for future releases is as follows:
- If necessary, additional 1.19 point releases to fix bugs
- Possibly a 1.20 release within the next 8 weeks
- After that will come version 2.0 firmware for the Series 2 Duets (WiFi and Ethernet) and their successors only. The firmware architecture will be changed to use a real time operating system (RTOS), which will make some of the future enhancements we have planned much easier to implement.
Great work David! Lots of nice features in 1.19!
Will 2.0 continue to support the beta Wifi boards? I assume they will since very little was changed between beta and release.
Yes
Are series 2 Duets what ships now or a newer rev. not yet out? I only just got mine.
I believe they are the duetwifi and duet ethernet, but not the duet 0.6 and duet 0.85. Correct me if Im wrong Tony, DC42.
That is correct.
1.19 working perfectly for me. Many thanks. I can see this has been a very busy period with the PCB effector as well as this update. Don't work too hard.
Thanks for the feedback!
Upgraded nicely, thank you for all the hard work
The Web UI still showing Vin instead of CPU temp and interval of Vin is in degrees Celsius.
It is supposed to display VIN where CPU temp used to be. It displays the units as V for me, not degC. Please go to the Settings page of DWC and verify which version of the web interface you are running.
You can see the MCU temperature if you click on "Extra" near the top left corner.
I am running DWC 1.19 final. Here's the output for a grep (unarchived the .zip and the language.xml.gz inside it). I am talking about the tooltip.
grep -i Minimum language.xml <string t="Minimum: {0} °C Maximum: {1} °C">Minimum: {0} °C Maximum: {1} °C</string> <string t="Minimum">MÃnimo</string> <string t="Minimum: {0} °C Maximum: {1} °C">Minimum: {0} °C Maximum: {1} °C</string>
Regardless of this bug, isn't the MCU temperature more important because it can vary a lot? Chances that Vin varies are small (toasted or underpowered supply). Motor EMF surges are short so they will not be displayed nor seen on the UI.
Thanks, I didn't spot that. Will fix it in the next version.
Chris moved the CPU temperature display to the Extra list because there is now the facility to display up to 10 additional temperatures, and there isn't room for all of them on the main page.
I am getting the error that "DuetWifiFirmware.bin is not valid for these electronics" HELP! I have done the erase and reset, but no luck.
I have tried it over Wifi and USB but I m getting the same issue.
Edit: I may have solved it, I have just seen that there is an additional few steps for upgrading firmware from 18.2 and below. I will give that a try!
Nope still the same problem:
SENT: M997 S0:1
READ: Error: Firmware binary "DuetWiFiFirmware.bin" is not valid for this electronics.
My guess is that you have not downloaded the firmware file correctly. It should be 321Kb in size.
Spot on seems there was a issue with the download. Now I have it all installed but apparently M587 is not recognized?
M587 will not work until you have enabled the WiFi module with M552 S0.
Ok I have followed everything and installed both firmwares simultaneously. Run the set Network macro and still M587 says unsupported?
Done!! Found the issue. The update support file (I can't recall it's name) was also corrupt when it was downloaded. Downloaded again. Now it all works like a charm!
David,
1. Are there any significant changes from the final RC to the release version?
2. Can you update using the web system from RC to release version?
Thanks!
Have you run M115 to check that you really are running version 1.19?
David,
Thanks!
1. Yes, but they will not be significant to most users.
2. Yes.
Could you please add details for the 1.19 upgrade specific to the Ethernet version. After following the Wifi instructions, I couldn't run M997 S0:1 (complaining about the 1), and when using the web interface to upload the WifiFirmware (renamed as per the instructions (I assumed WifiFirmware was the expected filename)) complained from M997 S0 (I figured what the hell, I'll try updating just one firmware) that DuetEthernetFirmware wasn't present. Now I'm wondering whether or not I need the WifiServer bin at all, or whether I'm not moving it from the Wifi Board to the Duet because actually that already happened when you set up the Ethernet firmware.
From what I can see, in the Settings>General tab, I am on 1.19 DWC and Firmware and, given that I'm seeing the UI at all, I assume the server aspect is working.
FWIW, I did leave in the GCODE instruction to specify the MAC Address and I do seem to have retained the same IP address. The instructions implied that it would be fixed from the unique board id, but happily the MAC address override still seems to work. But will that code be removed at some point?
All in all, I'd just like to check that everything is as it should be.
