Firmware 1.19 released
Ok I have followed everything and installed both firmwares simultaneously. Run the set Network macro and still M587 says unsupported?
Done!! Found the issue. The update support file (I can't recall it's name) was also corrupt when it was downloaded. Downloaded again. Now it all works like a charm!
David,
1. Are there any significant changes from the final RC to the release version?
2. Can you update using the web system from RC to release version?
Thanks!
Have you run M115 to check that you really are running version 1.19?
David,
Thanks!
1. Yes, but they will not be significant to most users.
2. Yes.
Could you please add details for the 1.19 upgrade specific to the Ethernet version. After following the Wifi instructions, I couldn't run M997 S0:1 (complaining about the 1), and when using the web interface to upload the WifiFirmware (renamed as per the instructions (I assumed WifiFirmware was the expected filename)) complained from M997 S0 (I figured what the hell, I'll try updating just one firmware) that DuetEthernetFirmware wasn't present. Now I'm wondering whether or not I need the WifiServer bin at all, or whether I'm not moving it from the Wifi Board to the Duet because actually that already happened when you set up the Ethernet firmware.
From what I can see, in the Settings>General tab, I am on 1.19 DWC and Firmware and, given that I'm seeing the UI at all, I assume the server aspect is working.
FWIW, I did leave in the GCODE instruction to specify the MAC Address and I do seem to have retained the same IP address. The instructions implied that it would be fixed from the unique board id, but happily the MAC address override still seems to work. But will that code be removed at some point?
All in all, I'd just like to check that everything is as it should be.
For the Duet Ethernet, it's a perfectly standard firmware and DWC upgrade through the web interface, except for the changing MAC address if you didn't specify one in config.g. I've no plans to remove the MAC address override gcode on the Duet Ethernet.
Thanks for the confirmation.
