FAN control
Im having trouble with the setup of my fans on WiFi 2 board.
I have a Chimera + hot end, with 2 parts cooling fans wired in parallel, as Cura doesnt allow individual contorl and it made my wiriing abit simpler.
I have the parts cooling fans connected to FAN0 output and Hotend fan to FAN1
I would like the below to work
- If H1 or H2 are above 50c, turn on FAN1. (currently working)
- Cura to control the parts cooling fans via gcode.
- Able to control the fans via the DWC (currently the sliders for TOOL FAN and FAN0 are linked together and they dont stay at the value selected. They will revert to 0)
Here is my config
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Feb 24 2021 12:07:14 GMT+1100 (Australian Eastern Daylight Time); General preferences
M550 P"V-King CXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes forwards
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M350 Z16 E16:16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z3200.00 E422.96:422.96 ; set steps per mm
M566 X900.00 Y900.00 Z150.00 E600.00:600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z600.00 E21600.00:21600.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z120.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z600 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X325 Y390 Z330 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T18000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X58 Y-10.8 Z1.45 ; set Z probe trigger value, offset and trigger height
M557 X0:290 Y15:370 S100 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as PT1000 on pin e0temp
M143 H1 S300 ; set temperature limit for heater 1 to 300C
M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as PT1000 on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S300 ; set temperature limit for heater 2 to 300C; Fans
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H1:2 T50 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P1 D1 H2 F0 ; define tool 1
G10 P1 X20 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T0 ; select first toolThanks
Ned -
@nedmo said in FAN control:
Able to control the fans via the DWC (currently the sliders for TOOL FAN and FAN0 are linked together and they dont stay at the value selected. They will revert to 0)1 and 2 should work as you have it configured now, does it not?
For 3, TOOL FAN and FAN0 slider are the same thing. Tool fan will control the part cooling fan of the currently selected tool, and both your tools use the same fan, Fan0.
The slider will work to adjust the fan speed, but during a print that has fan control commands it will constantly change when commanded to by the gcode file you are printing. Is that what you're seeing?
So when I slice a file, the gcode is controlling the hot end fan and part cooling fan is free to be adjusted by DWC slider.
The hotend fan will be controlled by the temperature of the heaters you've assigned.
The part cooling fan will be controlled by Cura. The slider will work to change the part cooling fan speed temporarily, but during a print it will go back to whatever speed cura has it set to the next time it changes in the gcode file.
In DWC there is a little Pin icon/button next to the slider that lets you lock the fan slider in place, but it only functions while dwc is open in the browser.
slicer is definitely controlling the hot end fan. Its speed increases at exactly layer 3 as per my settings. Part cooling fan remains off until its manually turned on by slider in DWC
Please show your sliced gcode file so we can see what the slicer is sending for fan control commands.
Are you sure you're got Fan0 and Fan1 connected the way you are describing?
Your config should be correct, but I can't see the wiring or the slicer commands.
Yep have confirmed that hot end fan is connected to FAN1 and part cooling is on FAN0
Here is gcode from slicer OFFROAD.gcode
Check your slicer for fan settings. If it's Cura, check the printer profile. It looks like you have it set to command Fan1.
M106 S127.5 P1
Note the P1.
