Duet 3 Mini 5+ supports polar?
Hi All,
I was wondering if the Duet 3 Mini 5+ supports the polar printer configuration?I assume I can still use external motor drivers as per my Duet ethernet?
Any thoughts would be much appreciated.
All the best
Barry M -
Polar: yes
External stepper drivers: in principle you could connect two external drivers to the daughter board connector, but you would probably need to level-shift them to 5V, and they would share a common enable signal which would be active whenever VIN power is present. To connect any more external drivers, you would need to use CAN-connected EXP1XD boards.
@dc42 Thanks for the information. That'd work for me.
