    Tool fan always on on FAN0
    Firmware installation
    • mrjoneskodundefined
      mrjoneskod
      Hi everyone,
      I have a Duet2 Wifi 1.03.
      I am having a strange part cooler fan behaviour after upgrading RRF 3. It all worked fine on RRF2.X and 1.X no hardware changes.
      I re-did the online configurator since some things changed and the BLtouch wasn't working, now everything is working but the tool head fan.
      I have the hotend fan is thermostatically controlled and should come on at 45C plugged on FAN1.
      The tool fan (FAN0) should work independently but it only turns on at 45C as well (thermostatic control is off), it never turns off even with an M106 S0. But it will come off if the head is below 45C.
      This is my config file.
      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Sun Feb 14 2021 15:34:33 GMT-0600 (Central Standard Time)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Duet Wifi"                                  ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S0                                     ; physical drive 0 goes backwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E154.30              ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
      M201 X900.00 Y900.00 Z50.00 E250.00            ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z800 E1200 I30                ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X-20 Y-8 Z0 S1                               ; set axis minima
      M208 X220 Y208 Z200 S0                         ; set axis maxima
      M574 X1 S1 P"!xstop"                               ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"!ystop"                               ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X27.3 Y0 Z0.0                             ; set Z probe trigger value, offset and trigger height
      M557 X0:200 Y0:200 S30                             ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 R0.490 C63.9 D9.77 S1.00 V24.2             ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S110                                       ; set temperature limit for heater 0 to 110C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 R5.496 C93.6 D2.04 S1.00 V24.3             ; disable bang-bang mode for heater  and set PWM limit
      M307 H3 A-1 C-1 D-1                                ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M950 F0 C"fan0" Q100                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 L0 H1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 L0 H1 T45                               ; set fan 1 value. Thermostatic control is turned on
      T0                                                 ; select first tool
      I can control the fans speeds with the slider in the web GUI if the hotends are above 45C, if the hotend is below 45C the slider control doesn't do anything.
      I have looked for answers and read the docs, but I can't seem to find a solution.
      Thanks in advance!
        @mrjoneskod said in Tool fan always on on FAN0:
        ; Fans M950 F0 C"fan0" Q100 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 L0 H1 ; set fan 0 value. Thermostatic control is turned off
        Change that H1 to H-1 to disable thermostatic control.
        mrjoneskodundefined 1 Reply Last reply Reply Quote 1
          mrjoneskod @Phaedrux
          @Phaedrux So simple, it worked perfectly.
          It was probably my mistake, thanks.
