Ender 5 + Duet wifi starts on wrong side g29
@lui2004 said in Ender 5 + Duet wifi starts on wrong side g29:
Endstops - X: at max stop, Y: at max stop, Z: not stopped, Z probe: not stopped
So that is when homed and you are X and Y not stop if not homed ?
Have you copied my homing all file ? and changed the motor direction . -
not all
only setup for :
Endstop,motor drive
@lui2004 X and Y , Z motor should be the same ( MUST ) , But E could be any direction , that is a suck it and see.
O.K , lets make a macro and see if we are on the same page.
Move the head it middle of the bed and try.
G91
G1 H2 Z5 F6000
G1 H1 X 10 F3000
G1 H1 Y 10 F3000
G1 H2 Z-5 F6000
G90Does it move to the right and too the back 10mm in each direction ?
If it doesn't change the motor direction until it does !!!!
the macro will only move the bed up and down
O.K to safe , it looks like you can see a 10mm change .
G91
G1 H2 Z5 F6000
G1 H1 X 100 F3000
G1 H1 Y 100 F3000
G1 H2 Z-5 F6000
G90This should lift the head up , move right and to the back 100mm now.
@peter247 said in Ender 5 + Duet wifi starts on wrong side g29:
G91
G1 H2 Z5 F6000
G1 H1 X 100 F3000
G1 H1 Y 100 F3000
G1 H2 Z-5 F6000
G90only z moves up and down few mm
but x and y dont moves
o.k confirm this :- After you run the macro and it goes up and down , does it say homed X an Y ?
yes after i run the macro it move only the z but x and y was homed
@lui2004 o.k wiser .
; Endstops M574 X2 S1 P"!xstop" M574 Y2 S1 P"!ystop"
So have you changed this and what too ?
yes i have changed it
@lui2004 With the ! ?
yes with the '!'
O.K , I'm hoping you are doing this which the head in the middle of the bed ?
Try removing the ! and try running the macro again.
it will move now with '!'
but the origin 0,0 back right the webinterface showa me back right 235,235
o.k , will have the switch Normally open or Normally close part working and tested .
( I will assume you are centring the head each time )
NEXT TEST , try the same macro , while it's moving touch the X axis switch first and it should stop and move in the Y direction , touch than Y switch and than should stop and say homed X and Y .
yes everytime in center the bed
Test succesfull x and y are homed
but why on right back ( 0,0 ) is now 235,235 and not 0,0 ?
Left , front is 0, 0 , right / back and fully homed should be 235 , 235 ,
Did my macro go right and back towards the X and Y homing switches ?IMPORTANT have you a Ender 5 ( not pro or plus )
a few change to the homing file , but it is now much easier to set up , now you don't have a bltouch but a switch for z axis .
