    DWC somehow unresponsive while heating
    Duet Web Control
    • Phil333
      Phil333 last edited by
      this was a 100% asked before, but I was unable to find it.
      When I set the temperature of the extruder via the DWC to lets say 200°C then I have to wait for the temperature to be reached before I can send additional commands.
      For example its not possible to set also the bed to 60°C before the extruder is at its desired temp.
      Is there a way to make it responsive to other commands while heating up?
      Thanks 🙂
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Phil333 last edited by
        @phil333 remove the M116 in the tool change files
        • Phil333
          Thank you @jay_s_uk !
          removing M116 ifrom
          tpost0.g and tpost1.g
          solved it 🙂
          • droftarts
            droftarts administrators @Phil333 last edited by
            @phil333 the other thing you can do is activate the tool first with active temperature set to 0, then set the temperature. That way no tool change command is sent, so tool change macros don’t run.
