    Duet 3 and BL Touch
    • akayoshi
      akayoshi last edited by
      Hi All,
      I'm setting up my BL touch on my Duet 3 board, but I can't seem to get the settings correct.
      My BL touch is Creality branded and has white, black, yellow, blue and red wires. I have followed the wiki guide and connected the plug to IO_7.
      The plug is wired as follows:
      3.3V -> left unpopulated
      IN -> White
      GND -> Black and Blue
      OUT-> Yellow
      +5V -> Red
      I have tested resistance from the terminal at the BL touch to terminal at the Duet 3 and the wiring is continuous.
      On startup, the BLtouch LED is frequently flashing in sets of 2 quick red pulses , and the pin does not move on M401/M402. The pin does not deploy on G30 and the hotend will crash into the bed if I don't Emergency stop.
      I have rewired the connectors, and also tried connecting to IO_4 & IO_5.
      I've replaced the BL touch pin, and even tried swapping the white and black wires without luck.
      Read the following pages as well...
      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
      https://duet3d.dozuki.com/Wiki/BLTouch_Troubleshooting
      https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/#Macros
      looking forward to your expert advice!
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 31 2021 21:23:47 GMT+1100 (Australian Eastern Daylight Time)
      M550 P"duet 3"                                     ; set printer name
      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
      M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
      M569 P0.2 S0                                       ; physical drive 0.2 goes backwards
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z180.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y1000 Z800 E800 I30                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X450 Y450 Z470 S0                             ; set axis maxima
      M574 X1 S1 P"io4.in"                               ; configure active-high endstop for low end on X via pin io4.in
      M574 Y2 S1 P"io3.in"                               ; configure active-high endstop for high end on Y via pin io3.in
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"io7.out"                                 ; create servo pin 0 for BLTouch
      M558 P9 C"io7.in" H5 F120 T6000                   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-41 Y5 Z2.5                              ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out2" T0                                 ; create bed heater output on out2 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out9" Q500                               ; create fan 0 on pin out9 and set its frequency
      M106 P0 S0 H T45                                   ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M563 P1 S"extruder 1" D0 H1 F0                     ; define tool 1
      G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      M501                                               ; load saved parameters from non-volatile memory
      deployprobe.g
      code_t; deployprobe.g
      ; called to deploy a physical Z probe
      M280 P0 S10 ; deploy BLTouch
      ext
      retractprobe.g
      ; retractprobe.g
      ; called to retract a physical Z probe
      M280 P0 S90 ; retract BLTouch
        Phaedrux Moderator @akayoshi last edited by
        @akayoshi What happens if you apply just 5v and ground? The probe should power up and do a self test if it's vertical at the time.
        Can you also provide the results of M122 and M98 P"config.g"?
        akayoshi 2 Replies Last reply Reply Quote 0
        • akayoshi
          akayoshi @Phaedrux last edited by
          This post is deleted!
          • akayoshi
            I worked it out last night. The creality branded bl touch loom was wired differently to what the guide indicates https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe . I bought a new bl touch and compared the terminals. I guess not all is lost, now I can install the spare bl touch on my second machine!
            The guide instructions
            3.3V - nil
            In - White
            GND - black and brown or blue
            Out - Orange or yellow
            +5V - Red
            The creality loom from left to right(with metal terminals facing you)
            white
            black
            yellow
            red
            blue
            The Official BL touch loom from left to right(with metal terminals facing you)
            brown
            red
            yellow
            black
            white
            So in the end I connected the duet end as follows:
            3.3V - Nil
            In - blue
            GND - red + white
            Out - Yellow
            +5v - black
            Hopefully this will help somebody else with a creality based BL-touch.
            Cheers
            P
