    No wifi en errors after update 1.19
    Firmware installation
    • Nengerman
      Nengerman last edited by
      Update via Usual procedure wifi failed.
      No connection more with wifi
      Fallback procedure #1
      • If WiFi is not working, but you can connect to the board via USB/Pronterface:
      • Take the on-board SD card out and put it in a computer,
      • Copy the new DuetWiFiFirmware.bin file to the /sys folder. It must be called exactly DuetWiFiFirmware.bin on the SD card. Also make sure that file iap4e.bin is present in /sys.
      • Replace the on-board SD card in the DuetWiFi
      • Restart the DuetWiFi and connect with Pronterface
      • Send command M997 S0 to install the firmware.
      • Disconnect Pronterface, then when the USB port disappears and reappears about 20 seconds later, reconnect.
      Connecting…
      Printer is now online.
      M997 S0
      SENDING:M997 S0
      [ERROR] Can't write to printer (disconnected?) (SerialException): Write timeout
      [ERROR] Can't read from printer (disconnected?) (SerialException): call to ClearCommError failed
      [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed ([Error 22] Het apparaat herkent de opdracht niet.)
      After that, the DuetWiFiFirmware.bin of the SD card has been removed.
      m115
      SENDING:M115
      FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.19 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-08-14
      And if I move the X and Y axis in Pronterface I get this error message
      Connecting…
      [ERROR] Traceback (most recent call last):
      File "printrun\printcore.pyc", line 241, in _readline
      File "printrun\pronterface.pyc", line 1713, in recvcb
      File "printrun\pronterface.pyc", line 1669, in update_pos
      ValueError: could not convert string to float:
      How can I solve this
        Did you read and follow the instructions prefaced IMPORTANT! on the download page when you updated the firmware?
        • Nengerman
          If you mean this page, yes
          https://duet3d.com/wiki/Updating_main_firmware
          • Dougal1957
            Dougal1957 last edited by
            no not that page at all this is the one you want https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
            Read it all carefully
            • Nengerman
              Can I try the Fallback procedure # 3
                If you have already installed main firmware 1.19 successfully, you don't needs to use the fallback procedure. Just copy the DuetWiFiServer-1.19.bin to /sys on the SD card and rename it to DuetWiFiServer.bin. Also create a /www folder on the SD card and extract the DuetWebControl files to /www on the SD card and described at https://duet3d.com/wiki/Upgrading_to_DuetWiFiFirmware_1.19. Then pop the SD card back in the Duet, restart it, send M997 S1 to install the wifi firmware, and proceed with the instructions for configuring your access point details.
                • Nengerman
                  It worked. It works.
                  Only confusing that there are several manuals for update firmware on the internet
                  Thank you for the assistance.
