    Duet wifi: motor phase B may be disconnected reported by drivers
    • joekoundefined
      joeko
      hallo,
      i did it. i own an duet 3 and in past also other duet 2 boards. now i bought an clone and i got problems. when i try to home an axis i get the warning "Warning: motor phase B may be disconnected reported by driver(s) 2 4" an that on all axis. i readed the howto about phase of the motor.
      but moving is possible. when i go to dwc and try moving than there is no problem but no homing. i tried different firmware, 2.xx and also 3.2.2 no different. at the moment i have only one motor connected without any endstop, heater or so.
      here is M122
      M122
      Driver 1: standstill, SG min/max 88/166
      has anyone a idea what the problem is ?
        droftarts administrators @joeko
        @joeko X and Y homing moves usually initially move Z +5mm, and I expect your config.g is set up with two Z motors, connected to drivers 2 and 4. You get that message because you have no motor connected to drivers 2 and 4.
        • joekoundefined
          joeko
          perfect, that fixed this 🙂
