Solved Installing macros
How do i install macros. I know its on the system tab.
i created a new directory caled macros. It showed up on the system lists of files...i assume this is right thing to Do. I downloaded file caled tuning but it is ziped
Do i load the entire zip file or unzip it first then install each macro????
I have no idea
Also is it possable i have the wrong file that is for a mack.. got the file off of one of the threads and they were talking later about os mac thought id better ask -
@ziggymanpopo
There should already be a folder called "Macros"
You can create files directly in this if you wish them to appear on PanelDue as a top level button, or you can create sub-directories to sort them. Each sub-directory will show on the Panel Due and DWC as well.
In your case you'd probably create a sub-directory called "Tuning" and upload each tuning macron into it. -
Ok so do copy and paste the ziped file in it's entirety. Or just is that wrong, do i need to unzip and and move the file into the macro one function at a time. Sorry just have no idea where to start some one suggested to pull the sd card then coppy the file to the macros folder that way . Still ...same question
Pluss do i need to prepair folders and a sub directory or does the dwc orginize the file somehow. -
I did find a macros tab in the dwc and it has 5 preinstaled macros so im getting closer cheesy grin . Thanks guys in advance
If you have a zip file of macros and there are a lot of them the easiest way to install them is to extract the zip file into the macros folder on the SD card in your computer.
So that a yes?? extract them got that then paste in macros folder "each fuction seperately???"
. Sorry first time ðĪŠ
I assume theres like 4 files one for each fuction? i paste them individually
Or is it an unzip and drag the whole folder.Im running windows could someone paste the proper
Link for your tunning file
Thanks again. -
Found it thanks
