Solved Duet3 - Schematic issues - BAT40V symbol
I see problems with the BAT40V symbol.
Is this symbol really defined in kicad symbols - "Diode.lib" ? I do no see it there and in DUET3.lib neither.Kicad: v5.1.6+dfsg1-1 release
Kicad symbols: 5.1.6-1
Duet3-Mainboard-6HC: commit edeb675Please help, Jan
@j2s I guess this is an issue with using an older version of KiCAD when the project was built compared to the one thats out now.
I have updated the github repository, should work now.
@t3p3tony I can confirm the issue fixed in commit d157c83 (https://github.com/Duet3D/Duet3-Mainboard-6HC).
Just for others, I see warning (see below) when I open the project but the schematic is fine now.
Warning maeeage (ignore it) :
This schematic was made using older symbol libraries which may break the schematic. Some symbols may need to be linked to a different symbol name. Some symbols may need to be “rescued” (copied and renamed) into a new library. The following changes are recommended to update the project.Thank you t3p3tony, good job!
PS: The kicad version I use is current version for Ubuntu 20.10 .
