Toolboard amperage question
Quick question about the toolboard. We are about to test the new Slice Magnum+ hotend with 100w heater that will be pulling around 4 amps. Will the toolboard be able to support this?
I think I just found the answer on the Wiki:
- One high current output (OUT0) intended for extruder heater, maximum current 5A.
Looks like we'll be in good shape! Thanks
@oozebot, when using a heater current that high, be sure to use ferrules on the ends of the heater wires.
So... check it out. The new Slice Magnum+ with two 50w heaters. Will be launching soon..
Next to the original Magnum (temporarily mounted on our upcoming IDEX machine)
And another shot all wired up to the toolboard on it's new home - a 16" x 16" x 24" hoss we are just wrapping up.
