Solved Idiot check: PS_ON Duet 2
Morning,
Double checking my understanding of the PS_ON ratings.
On the first generation Duets I believe this was limited to 5V. On the Duet 2 the MOSFET according to the schematic is PMV40UN2, which has a rated drain source voltage of 30V. As far as I can see then this can take full V_IN voltage, or more importantly I will be able to drive a pair of automotive relays as long as flyback/freewheel/kickback-suppression diodes are in place?
Thanks,
Wesley.
@doctrucker said in Idiot check: PS_ON Duet 2:
Correct.
@dc42 Thanks.
