    param.P doesn't return macro name
    Gcode meta commands
    • OwenDundefined
      OwenD
      It seems that the "P" parameter of M98 is captured by RRF and not exposed to the new param meta code
      I'm guessing it's too deeply entwined in other code, but thought I'd check.
      If I send
      M98 P"0:/macros/TestMacro" A1 B"MyString"
      and TestMacro.g contains
      echo param.A
      echo param.B
      echo param.P
      Then the A * B parameters will be returned but the P arameter casues an error
      1
      MyString
      Error: in file macro line 3 column 13: meta command: unknown parameter 'P'
        dc42 administrators @OwenD
        That's correct, the M98 P parameter is not included, on the grounds that it's not normally of interest because you know what file you are running.
        • OwenDundefined OwenD referenced this topic
