    Improved homing macros
    Gcode meta commands
    1.6k
    • ww1g16undefined
      ww1g16
      Morning all!
      Just thought I'd share a macro that has saved me a lot of time since implementing it. It's for homing x and y taking advantage of the axis measuring feature to detect if sensorless homing on any axis was bad (triggered too early). I use sensorless homing on a CoreXY and it can be a bit finicky over time and sometimes give me vastly incorrect homing. With these new homing macros for X and Y, both axes are measured and compared to their set length. It's likely not going to be a drop-in replacement for your own machines, but perhaps something similar could be useful.
      Normal homing behaviour for me:
      • Bump Xmax
      • Bump Ymax
      • Wait at Xmax, Ymax to proceed with other start gcode
      New homing behaviour:
      • Bump Xmin
      • Measure distance to Xmax. If shorter than expected (aka bump Xmin triggered too early, or travel to Xmax stopped too early), abort if unable to home after n retries
      • Bump Ymin
      • Measure distance to Y max. If shorter than expected (aka bump Ymin triggered too early, or travel to Ymax stopped too early), abort if unable to home after n retries
      One note to add is that this of course requires either an endstop at both min and max of both axis, or something to bump against at both ends if using sensorless. This meant for me I had to add something to bump against at Ymin, otherwise my print head would be the first thing to crash into the front of my corexy.
      Hope it's useful!
      (note, comments in the code are outdated so take them with a pinch of salt)
      ; homex.g
      ; called to home the X axis
      ;G1 Xnnn Ynnn Znnn H0	Ignore endstops while moving.
      ;G1 Xnnn Ynnn Znnn H1	Sense endstops while moving (ignoring the axis limits).
      ;G1 Xnnn Ynnn Znnn H2	Ignore endstops while moving. Also ignore if axis has not been homed. On Delta and Core XY, axis letters refer to individual towers.
      ;G1 Xnnn Ynnn Znnn H3	Sense endstops while measuring axis length, setting the appropriate M208 limit to the measured position at which the endstop switch triggers.
      M400				; Make sure everything stops
      var x_backoff = 10
      var x_max = move.axes[0].max
      var x_min = move.axes[0].min
      var x_length = var.x_max - var.x_min
      M566 X50.00 Y50.00     			; Set maximum instantaneous speed changes (mm/min)
      M201 X500.00 Y500.00      		; Set accelerations (mm/s^2)
      M913 X50 Y50    ; Set current for X axis to 60% of normal value
      M915 X Y S2     ; 0 is too sensitive, 4 isnt sensitive enough.
      G91              		; relative positioning
      G1 H2 Z5 F{60*60}   	; Lift Z a little.
      while true
      	if iterations = 20
      		M18 X
      		G1 H2 Z-5 F{60*60}  ; lower Z again
      		G90              ; absolute positioning
      		M913 X100 Y100		; Reset motor currents
      		M98 P"0:/macros/Parameters"
      		abort "Too many auto calibration attempts"
      	M574 X1 S4              ; Set endstop configuration: low end on X (1), single motor load detection (3)
      	G1 H1 X-999 F{60*60} 	; Move to X_min
      	G1 H0 X{var.x_backoff} F{60*60} 		; Back off a little
      	M574 X2 S4              ; Set endstop configuration: low end on X (1), single motor load detection (3)
      	G1 H3 X999 F{60*60} 	; Move to X_max, set x measured length
      	G1 H0 X{-var.x_backoff} F{60*60} 	; Back off a little
      	var x_measured_length = move.axes[0].max - move.axes[0].min
      	echo {"Set length: " ^ var.x_length ^ "mm"}
      	echo {"Measured length: " ^ var.x_measured_length ^ "mm"}
      	M208 X{var.x_min}:{var.x_max}
      	if var.x_measured_length >= var.x_length
      		G92 X{var.x_max-var.x_backoff}
      		break
      	echo "Repeating homing, axis length is too low. Measured (" ^ var.x_measured_length ^ "mm) < Set (" ^ var.x_length ^ "mm)"
      	G4 S1
      echo "X Homing Successful"
      ; homey.g
      ; called to home the Y axis
      var y_backoff = 10
      var y_max = move.axes[1].max
      var y_min = move.axes[1].min
      var y_length = var.y_max - var.y_min
      while true
      	if iterations = 20
      		M18 Y
      	M574 Y1 S4              ; Set endstop configuration: low end on X (1), single motor load detection (3)
      	G1 H1 Y-999 F{60*60} 	; Move to X_min
      	G1 H0 Y{var.y_backoff} F{60*60} 		; Back off a little
      	M574 Y2 S4              ; Set endstop configuration: low end on X (1), single motor load detection (3)
      	G1 H3 Y999 F{60*60} 	; Move to X_max, set x measured length
      	G1 H0 Y{-var.y_backoff} F{60*60} 	; Back off a little
      	var y_measured_length = move.axes[1].max - move.axes[1].min
      	echo {"Set length: " ^ var.y_length ^ "mm"}
      	echo {"Measured length: " ^ var.y_measured_length ^ "mm"}
      	M208 Y{var.y_min}:{var.y_max}
      	if var.y_measured_length >= var.y_length
      		G92 Y{var.y_max-var.y_backoff}
      		break
      	echo "Repeating homing, axis length is too low. Measured (" ^ var.y_measured_length ^ "mm) < Set (" ^ var.y_length ^ "mm)"
      	G4 S1
      echo "Y Homing Successful"
      o_lampeundefined 1 Reply Last reply Reply Quote 3
      • o_lampeundefined
        o_lampe @ww1g16
        @ww1g16
        That's a good thing to have, but I thought, we'd have to home XY at once for a CoreXY?
        Another thing is the 'backoff' move. Shouldn't you increase the motorcurrent first, to make sure this move doesn't cause an error?
        Why do you abort the macro? Instead increase motorcurrent on every iteration, until it is high enough.
