    Uploaded 3.2.2 too soon
    Firmware installation
    414
    • TNCundefined
      TNC
      I inadvertently uploaded 3.2.2 firmware before updating config g. after 2.05 to 3.0
      update. Ball screw motor not to responding to triggered Endstop.
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
      Duet WiFi Server Version: 1.25
        Is there a question? Do you have a config file set for RRF3.x yet?
        TNCundefined 1 Reply Last reply Reply Quote 0
        • TNCundefined
          TNC @Phaedrux
          @phaedrux generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 18 2021 08:29:16 GMT-0400 (EDT)
          Why isn't Endstop working? config g. below; Configuration file for Duet WiFi (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 18 2021 08:29:16 GMT-0400 (EDT)
          M550 P"TNC400" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X320.00 Y320.00 Z320.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z12000.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X400 Y400 Z400 S0 ; set axis maxima
          M558 P5 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:215 Y15:195 S20 ; define mesh grid
            Phaedrux Moderator @TNC
            @tnc said in Uploaded 3.2.2 too soon:
            Where are your endstops physically located on the printer?
            Where are they physically wired on the board?
            Post your homing files as well.
            • TNCundefined
              TNC
              @Phaedrux
              2D0574F8-2D09-41DF-A5AD-790FBED08A15_1_201_a.jpeg 2E6EA8C3-4283-4C26-BECB-BE85B064E5ED_1_201_a.jpeg
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 18 2021 08:29:17 GMT-0400 (EDT)
              G91 ; relative positioning
              G1 H1 X-405 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
              G1 H1 X-405 ; home X axis
              G1 H1 Y-405 ; home Y axis
              G1 X5 Y5 F6000 ; go back a few mm
              G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y-405 ; then move slowly to Y axis endstop
              G1 H1 Z-405 F360 ; move Z down stopping at the endstop
              G90 ; absolute positioning
              G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
              ; homex.g
              ; called to home the X axis
              G1 H1 X-405 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000 ; go back a few mm
              G1 H2 Z-5 F6000 ; lower Z again
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-405 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000 ; go back a few mm
              G1 H1 Y-405 F360 ; move slowly to Y axis endstop once more (second pass)
              ; homez.g
              ; called to home the Z axis
              G1 H1 Z-405 F1800 ; move Z down until the endstop is triggered
              ;G91 ; relative positioning
              ;G1 Z5 F100 ; lift Z relative to current position
              ;G90 ; absolute positioning
              I greatly appreciate your help with my situation!!!
                Ok do you have a motor connected to X driver and an endstop connected to the Xstop input.
                If the endstop is connected correctly you should be able to see the LED on the board change when you click the endstop.
                Also you should be able to send M119 to see the status of the endstops. What does it tell you when the endstop is clicked? What does it tell you when it's not clicked?
                If M119 tells you that it's triggered when it's clicked you should be able to test it by sending G1 H1 X200 F600 in the console. This will move the X motor until you click the endstop.
                See here about connecting endstop switches.
                https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
                • TNCundefined
                  TNC @Phaedrux
                  @phaedrux
                  Triggered
                  No movement w/G1 H1 X200 F600 in the Console.
                  Everything seems to work fine from dashboard, except
                  endstop and Error message below.
                  Warning: motor phase A may be disconnected reported by driver(s) 0 1
                  Warning: motor phase B may be disconnected reported by driver(s) 1
                  I'll revisit (X-drive) termination @board. Error follows termination point.
                    Yes I'd say you have a wiring problem.
                    Check your phases using this technique and try again.
                    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                    maybe bad crimp or broken wires?
                    • TNCundefined
                      TNC @Phaedrux
                      @phaedrux
                      Thanks. I'm on it!!! Question: What bearing will non-upgrade of config.g
                      after 2.05 to 3.0 RRF have. Can those file changes be done in 3.2.2 RRF?
                        If you don't have a config file ready for RRF3 nothing terrible will happen, you just won't have any functionality since the endstop and heater syntax is completely different.
